Greetings everyone,
I'm thinking about re-capturing and storing my Mini-DVs as interlaced compressed footage.
The first time I digitalized them I had to choose whether to keep them interlaced or deinterlace them using QTGMC when it was time for compression.
Now I'm wondering if I could convert the raw interlaced footage as interlaced compressed videos and deinterlace them whether I wanted, to keep a "clean" version of my tapes.
Does deinterlacing compressed videos would make a notable difference in quality compared to deinterlacing raw footage.
I must clarify that my main objective is to preserve my tape in the best quality without having to store 40GB files for each tape on my hard drive.
Thanks for considering
				Results 1 to 16 of 16
	Haven't captured for ages, but as I remember, 90 minutes of DV video encoded with lossless FFV1 amounted to around 8.5 GB to 11.5 GB.
 That is less than a third of your 40GB and since it's lossless, so quality got lost. (no need to deinterlace)
 If you are not planning to compress the data to a lossless format, I would (bob) deinterlace with QTGMC.
 For lossy compression, whether the quality difference is large or not and whether the detail loss is high or not is up to your choice. Depending on the format and settings, the output will be smaller with less information or not.
 Personally, I would go for lossless compression.users currently on my ignore list: deadrats, Stears555, marcorocchini
	QTGMC is by default a bob deinterlacer, each field gets converted to one frame and thus the frame rate and count doubles.
 It can be used as a same-frame-rate deinterlacer, by throwing half of the created frames away.
 Be sure to keep all motion information, bob deinterlacing is recommended.users currently on my ignore list: deadrats, Stears555, marcorocchini
	Why would one "re-capture" MiniDV at all, taking the analog AmarecTV route? Wouldn't it be more straightforward - and absolutely lossless - to just transfer (=copy) the interlaced digital video of miniDV to the PC via firewire/i-link/IEEE1394 and continue from there with postprocessing?
	Side question: Are there Firewire to USB adapters that work with WinDV (that is what I used ages ago) or what is the usual way to transfer DV content to PCs without Firewire? (Does one need an extension card?)
 I agree, if possible, Mini-DV copying to PC and then lossless compression would be the best way for archiving.users currently on my ignore list: deadrats, Stears555, marcorocchini
	I might be missing the point, but if space allows, wouldn't it be better to store DV as its native DV since that's already lossless/native? It should take around 13GB per hour in DV form assuming you are using consumer DV formatted tapes.
 @Selur - The one Firewire to USB device outside of an Apple Thunderbolt to Firewire Adapter Plus Thunderbolt 2 to USB-C/Thunderbolt 3 (which requires a thunderbolt capable USB-C port) that I'm aware of would be the Pinnacle Studio MovieBox which happens to have a firewire input and will go to USB 2.0 and I believe requires drivers to do so. Ideally, you'd use a PCI-E firewire card but that's only really an option if you have a desktop Windows PC.
	Thanks for the info.
 Ah, I thought it would be ~25GB per tape.It should take around 13GB per hour in DV form assuming you are using consumer DV formatted tapes.
 Depending on the needs, 13GB per hour might be already okay.users currently on my ignore list: deadrats, Stears555, marcorocchini
	"Transfer" (not "capture") DV using Firewire at 13GB per hour. It stays Interlaced. If you can't transfer via Firewire (eg PCIe card in a modern Win 10 or 11 PC) use the DV>USB route as Aramkolt says; Pinnacle 510/710-USB or a Panasonic Mini-DV camcorder that will output DV over USB.
 As a last resort, do an analogue lossless capture.
	Firewire -> Thunderbolt -> Thunderbolt 3 also works if your laptop has a Thunderbolt 3 port. Sure it's a daisy chain of two Apple branded adapters but it's an option
	Nice, good to know. users currently on my ignore list: deadrats, Stears555, marcorocchini
	In fact, I was using a laptop all the time since my desktop computer is slower. That's why I didn't consider firewire.
 I already heard about it, I think I just need a bit of trickery to make this work on laptop, since it's not an apple one.
 After checking internet it seems that I either need a PCIe firewire slot on my computer or a thunderbolt one.Last edited by Hamilthon; 10th Apr 2025 at 01:05.
	2 years old now but interesting info on using a Thunderbolt solution with Intel 12th gen and later processors...
 https://www.youtube.com/watch?v=u3OIcw4QH1w
  Issues Deinterlacing DVCam FootageBy Tom619 in forum RestorationReplies: 53Last Post: 1st Nov 2023, 08:56
  Need help with Hybrid Deinterlacing footageBy Arizona Papi in forum Video ConversionReplies: 4Last Post: 25th May 2023, 14:50
  How to recover raw Logitech webcam footageBy JJonah in forum Video ConversionReplies: 7Last Post: 20th May 2023, 08:15
  Deinterlacing wrongly encoded footageBy Xyena in forum Newbie / General discussionsReplies: 29Last Post: 1st Jun 2022, 06:34
  Image "Swimming" when deinterlacing camcorder footageBy P-Rock in forum Video ConversionReplies: 9Last Post: 26th Jul 2020, 16:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
