  1. Capturing Memories dellsam34's Avatar
    Jan 2016
    I recently had a VirtualDub2 x64 v2.2.0.755 re-install and now it can't open multi audio channel Quicktime lossless video files which previously opened them fine, The error says: "FFMPEG: Unsupported channel layout.", Any ideas?
    File info:
    General
    Complete name                            : E:\Capture0000.mov
    Format                                   : QuickTime
    Format/Info                              : Original Apple specifications
    File size                                : 996 MiB
    Duration                                 : 34 s 501 ms
    Overall bit rate                         : 242 Mb/s
    Frame rate                               : 29.970 FPS
    Encoded date                             : 2000-01-01 00:16:43 UTC
    Tagged date                              : 2000-01-01 00:16:43 UTC
    Writing library                          : Apple QuickTime
    Video
    Format                                   : YUV
    Codec ID                                 : v210
    Codec ID/Hint                            : AJA Video Systems Xena
    Bit rate mode                            : Constant
    Bit rate                                 : 224 Mb/s
    Width                                    : 720 pixels
    Clean aperture width                     : 704 pixels
    Height                                   : 486 pixels
    Clean aperture height                    : 480 pixels
    Display aspect ratio                     : 4:3
    Clean aperture display aspect ratio      : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 (30000/1001) FPS
    Standard                                 : NTSC
    Chroma subsampling                       : 4:2:2
    Bit depth                                : 10 bits
    Scan type                                : Interlaced
    Scan type, store method                  : Interleaved fields
    Scan order                               : Bottom Field First
    Compression mode                         : Lossless
    Bits/(Pixel*Frame)                       : 21.333
    Stream size                              : 920 MiB (92%)
    Language                                 : English
    Color primaries                          : BT.601 NTSC
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.601
    Audio
    Format                                   : PCM
    Format settings                          : Little / Signed
    Codec ID                                 : lpcm
    Bit rate                                 : 18.4 Mb/s
    Channel(s)                               : 16 channels
    Sampling rate                            : 48.0 kHz
    Bit depth                                : 24 bits
    Stream size                              : 75.8 MiB (8%)
    Language                                 : English
    Other
    Type                                     : Time code
    Format                                   : QuickTime TC
    Time code of first frame                 : 00:00:00;00
    Time code of last frame                  : 00:00:34;13
    Time code, stripped                      : Yes
    Language                                 : English
    Jan 2016
    Update:
    I installed VirtualDub2_44282 and it works now, Screw the current year 2025 version, it's useless.
