I would like to buy a display card with capture function, I m a non-game user, OS:windows 2000pro Hardware:AMD 1.2G Epox-8KTA3+PRO 512MB ram,and 60GB IDE raid harddisk, MAinly use for capture VHS, V8 to SVCD,VCD which one is good quality for video capture?
1.Asus V7100 Deluxe Combo,
2.G450etv,
3.ATI All-in-Wonder Radeon
Thanks...
Matrox makes bitchen cards and they have the functionality of a great dual head ability for when you decide to start playing with that.
I have the All In Wonder Pro 128 which is a great card as well but the dual head is kind of screwed up. (if you are into that) Capture on it is great and the install was easy.
Haven't used the other card so i have no comment on that one.
I would choose the Matrox card if i were to choose a new card again. Even though i am happy with my ATI. Go Matrox. -
I am having good results with the ATI Rage Fury Pro. It has video in AND out but no tuner and costs considerably less.
Recommend Capture card/stick pls
By jubbely2 in forum Capturing and VCRReplies: 5Last Post: 27th Oct 2010, 13:14 -
Can any one recommend a tv capture card?
By Stevet1972 in forum Video Streaming DownloadingReplies: 2Last Post: 19th Nov 2009, 07:08 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 18:52 -
"Upside down converter you turning me, inside out and round and round
By Blå_Mocka in forum Video ConversionReplies: 2Last Post: 18th Feb 2008, 13:23 -
Recommend a wireless card?
By Poppa_Meth in forum ComputerReplies: 17Last Post: 25th Nov 2007, 21:37
