I found this thread: https://forum.doom9.org/showthread.php?p=1568963#post1568963
Sadly i don't understand what this code means. Is this somehow possible to make with hybrid ? I mean the Pictures looks very nice for me. But Maybe it is only because the source works with that. I normally use DetailSharpen 0.5-0.7 Strength and i like it very much.
Most "remaster" of Movies i see looks bad/overprocessed. This looks nice for me (but maybe it is because the picture is so small. If i zoom in, it looks pixelated).
LSFmod, Detailsharpen and Finesharp are available in Hybrid.
The code mentioned there is what Didée turned into FineSharp,...
You can also use CAS and/or add some line darkening to make stuff seems sharper,..
Note that all these sharpen filter only emphasize details, they do not add them, so a blurred source will not magically gain details,...
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Ahh yes. Ok, maybe this was just a good source. Because i tried FineSharp already and for me it does always make it look pixelated. So then i think i will stay on CAS or DetailSharpen. CAS looks basically the same as DetailSharpen for me. Also i tried LSFmod which is an option. It has its on up- and downsides. I like CAS and Detailsharpen. they just sharp everything. But you have to make sure there is no grainy background.
And yes, i know. I do only sharp a little bit. I often used SMDegrain with TemporalRadius2, SAD300, Contr.Sharp -1 in hybrid + Detailsharpen 0.5 in Strength.
Still there is no good option for Upscaling real stuff. Tried again some models, but they do still the same bad results (except you have 320p Input Resolution and 100GB VRAM graphics card
That's why i am trying to use light-sharpening or trying to find some wonder-sharpener.
But thanks for your answer. -
All the image enhancer models are really only usable for anime/cartoon or single images due to the lack of temporal coherence (you end up with flickering).
Especially if they would add believable details, you would end up with a flickering mess.users currently on my ignore list: deadrats, Stears555, marcorocchini
Using VSDC to make a GIF and I want to adjust the scale and resolution.
By Xarzu in forum EditingReplies: 1Last Post: 28th Feb 2024, 05:11 -
Best GoPro Resolution to make DVD and BluRay
By BaruceBR in forum Newbie / General discussionsReplies: 21Last Post: 22nd Feb 2023, 10:49 -
Why do people say TV shows shot on film were higher resolution than...
By 90sTV in forum Newbie / General discussionsReplies: 56Last Post: 28th Nov 2021, 12:36 -
Question how to download Facebook video in higher resolution
By jimdagys in forum Video Streaming DownloadingReplies: 15Last Post: 18th Nov 2021, 21:32 -
Shooting in a higher resolution than the final render: Pros and Cons
By tedsled in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2021, 13:05
