Hi
I'am trying to remove some grain. Im not sure, if this is actually grain, but it is often happening on movies with grain, when there is a night-scene. The grain is moving around very hard then and also the grain is big/large. It is super bad, when there is fog in the nigth.
I have a 10s clip. Look on the lower right corner (first two seconds).
When i use a degrainer, it does just not work as it should (or as i want)
Has anyone a tip how i can solve that (without blurrying everything out)? I basically want just black in a black night. But when i degrain i get even "bigger" and harder moving grain than before degrain.
EDIT: Here is the videoclip: https://uploadnow.io/f/15fZTQ7
Results 1 to 21 of 21
Tip: Luma limit masking
oh, just noticed, I cropped the video before processing, since I had the crop values of another file still configured
-> re-uploaded the file
Image comparision: https://imgsli.com/MzY2NTE2Last edited by Selur; 4th Apr 2025 at 08:54.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Which video editing software program might you be using?
If you are wanting to remove digital noise/grain, the Neat-Video plug-in may suit your needs if you using compatible video editing software.
I use the plug-in extensively [with Sony Movie Studio 12 and Vegas 18/19/20] and am always impressed with how effective the results can be, even with nighttime footage with very noticeable noise. -
I use Hybrid as Software. And i don't use Paysoftware
Hmm, when i watch the video it looks quite good, but when i look at the pictures it looks very bad. Don't understand why.
But can i do that with the mask with hybrid? Does mask mean i have to manuall mask each frame or sth like that or does it do that by itself ?Last edited by Platos; 4th Apr 2025 at 09:36.
Hybrid has some basic masking (and other extended) controls, which are usually not shows.
- Enable 'Filtering->Vapoursynth->Misc->UI->Show 'Masked'-controls. (to see the masking controls)
- Enable for example 'Filtering->Vapoursynth->Denoise->MC Temporal Denoise' with 'Settings' 'very high'.
- Enable 'Masked' (LimitMask with Limit 30 and inverted, is the default; adjust settings to your liking)
Cu Selur
Ps.: Enabling all the extended controls:
usually is a bad idea
@ Selur: Thanks, i will have a look on it and try to do what you did.
@ Jagabo: Yes, that is what happens, when you degrain alot (instead of grain it has now heavy "banding" or "blocking"-like artifacts). For me this is more visible than little grain. Maybe it's just in my eyes, but for me it is worse. That's the problem with Degraining: Instead of removing the grain, it makes the "grains" bigger and moving heavier around (expect you degrain so hart, that everything is washed out). I Also found out, that you need to make a super high crf-setting, if you want to have small grains in dark scenes.
I have to try the masking-thing, but i fear it is very time consuming. So i will just let the grain stay if it is not a fast thing.
(I already used SMDegrain, not on the video above, but i already tried it.) -
About the banding: apply debanding
About keeping grain: try adaptive quantization
Cu Selur
Ps.: if machine learning is an option, DPIR denoise usually works fine on such content.Last edited by Selur; 4th Apr 2025 at 17:06.
You can try something like
Code:v=ffms2("superkurz.mkv") mask=mt_binarize(v,threshold=20,upper=true).grayscale().blur(1.5).blur(1.5).blur(1.5).blur(1.5) #play with the threshold value black=BlankClip(color=color_black, width=width(v), height=height(v), pixel_type="YUY2") res=overlay(v,black,mask=mask,opacity=0.9,mode="blend") #play with the opacity value return res #return interleave(mask,v,res) #interleave for debuggingLast edited by Sharc; 5th Apr 2025 at 06:21.
Yes, that is how degraining works. Pixels are averaged with the pixels around them, spatially and/or temporally. Small dots are replaced with bigger, longer lasting, less intense dots.
The first thing to go with strong video compression is fine grain. It also helps to work/compress in 10 bits (or more) rather than 8 bits.
As was shown by Sharc, building a mask based on brightness is pretty simple. I would have used a "smoother" mask, something like:
Grain doesn't bother me at all. I wouldn't bother removing it unless I had some other reason (like needing a highly compressed video).Code:mask = Tweak(bright=-20, coring=false).Tweak(cont=40.0, coring=false).Invert().Blur(1.0)
@Sharc:
This looks good, but i don't know how to do that in hybrid
@ Jagabo: I don't like grain, that's why i make it away. But i could live with some rare scenes, where grain is still there. I always remove grain. But what do you mean with fine grain on strong video compression? You mean you would apply fine (small) grain to cover the compression artifacts? Because that's quite difficult, when the artifacts are big and the grain is small.
Is DPIR somehow possible with Hybrid (that i can do all in one encoding)?
And i tried it with the masking. Works quite well, i have to optimze Debanding-settings, but works. Is the "normal" masking in hybrid the luma limit masking you said ?
And about Masking: Is it somehow possible to make the masking-thing only on some specific scenes ? So can i somehow say "do that only from 25min30s to 26min30s" for example ?
(Btw: Hybrid is just the best tool ever. Thank you again) -
Yes, both the torch- as the vs-mlrt- add-on offer DPIR.Is DPIR somehow possible with Hybrid (that i can do all in one encoding)?
if you enable the masking controls, the first available mask is the LimitMask which is the luma limit mask that I used.Is the "normal" masking in hybrid the luma limit masking you said ?
Yes, aside from masking, Hybrid also has 'Apply only to'-controls which allow specifying, frame ranges between which the filter will be applied.Is it somehow possible to make the masking-thing only on some specific scene
Hybrid doesn't use time ranges, but frame ranges, but it's possible.So can i somehow say "do that only from 25min30s to 26min30s" for example ?
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I'am trying to reproduce your result, but i don't reach it. Could you tell me your filter-settings in hybrid? You already postet the settings of MC Temporal Denoise in a picture, but what Settings are you using with GradFun3Mod Debanding for your uplaoded result?
And is there actually a reason why you use denoise and not degrain? Because this is an old movie which probably have analog tape. Or is Denoise better for this kind of stuff?
And i want to degrain the whole movie a bit (standart-settings on SMDegrain + contr.Sharp -1). Could i now use SMDegrain and use MC Temporal Denoise a+ Debanding only for these framerange ? Or would you not recommend to do that ?
I will try that, but first i have to ask chatgpt what the code means to undertstand it ^^ Or maybe let it "convert" to sth vapoursynth. -
afk today,...
I used MCTemporalDenoise since looking at the source with Retinex applied showed strong artifacts.
No clue what GradFun3Mod setting I used there. Add Retinex, move it to the bottom of the filter list and then try which GradFun3Mod values (my guess is 1.5) have what effect in the Vapoursynth Preview.
Ok thanks, i will try it.
How do i make the "apply only to" working? When i check "range" and then write "20-100" it does not work. It says sth from "a-z" but how can i know which frames that are? What do i have to write in there when i want it to apply from Frame 20-100 for example? -
You read the tool-tip:How do i make the "apply only to" working?
and specify your range,...Each line in the text file or in the mappings string must have one of the following forms:
'a z'
Replaces frame a in the base clip with frame z from the filtered clip.
'[a b] z'
Replaces all frames in the range [a b] of the base clip with frame z from the filtered clip.
'[a b] [y z]'
Replaces all frames in the range [a b] in the base clip with frames in the range [y z] from the filtered clip. If the input and output ranges do not have equal sizes, frames will be duplicated or dropped evenly from [y z] to match the size of [a b]. If y > z, the order of the output frames is reversed.
Since this uses remap.Rfs, you can also read that documentation. https://github.com/Irrational-Encoding-Wizardry/Vapoursynth-RemapFrames
Yes, you did use a syntax that is not supported -> read the tool-tipWhen i check "range" and then write "20-100" it does not work.
Use the Vapoursynth Preview.It says sth from "a-z" but how can i know which frames that are?
What do i have to write in there when i want it to apply from Frame 20-100 for example?Cu SelurCode:[20 100]
Thanks man! Then i will do it now on specific frame-range, thanks.
I did now manage to find good settings (GradFun3Mod was not good). I used MCTemporalDegrain verylow (masked) + vsPlacebo (Debaning) on default (also masked) + regular SMDegrain default + Contr.Sharp -1 + DetailSharpen Strength 0.7.
The magic makes vsPlacebo. MCTemporal is not the main thing here. I got always huge Banding and GradFun3Mod could not eliminate it at all no matter what settings i tried (maybe i just don't know how). But it works now.
On Interest here is the result: https://uploadnow.io/f/YbrmK2V -
Happy, you found a solution to your liking.
Hey everyone,
I’ve been following this thread and it’s been really insightful! I’ve also struggled with grain in dark scenes before, especially with older footage, and I wanted to share something I’ve tried that might help. Has anyone experimented with adjusting the luma levels before applying a denoise filter? I found that slightly boosting the brightness in those super dark areas can sometimes make the grain less harsh, and then the denoise filter (like SMDegrain or MCTemporal) seems to work a bit better without causing as much banding. Not sure if it’ll work for everyone, but thought I’d throw it out there! Also, I noticed some of you mentioned masking, does that help with keeping details in brighter areas intact? Sorry if I mispelled anything, I’m typing this late at night!
YesAlso, I noticed some of you mentioned masking, does that help with keeping details in brighter areas intact?users currently on my ignore list: deadrats, Stears555, marcorocchini
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 22:45 -
getwvkeys.cc code":400,"error":true,"message":"Failed to get license: 405
By Koldunas in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2023, 03:44 -
{"code": 2048, "message": "Authentication failed"} when getting license
By warmachine in forum Video Streaming DownloadingReplies: 2Last Post: 26th May 2023, 17:34 -
How to change "m3u8" to "json" and "ts" to "js" extension
By wowza in forum Newbie / General discussionsReplies: 6Last Post: 4th Mar 2023, 16:36 -
PotPlayer 3 Qs: load exported settings; get rid of "Scenes(...)" tabs; etc
By fabiospark in forum Software PlayingReplies: 0Last Post: 1st Nov 2020, 12:36
