Ok guys......I need your help once again. I know I am a little behind the times here, but I have finally just purchased a DVD rom drive for my system, and now I want to know if there is any (the keyword being- EASY) way to copy a DVD to a CDR without going thru the whole encoding process???? I know, I know, I have taken a look at Sefy's guide and I just was curious as to if there is a simple program out there that will just let you copy one. I am really curious what the quality will be. I mean do you have to go thru the entire encoding process, just like an avi? Or is there any such program that you can just put the DVD in the drive and then a CDR in the CDRW drive and hit "COPY" ???
Results 1 to 9 of 9
Try DVDX for about the easiest process
Otherwise, place DVD onto your scanner, press copy button -
"Otherwise, place DVD onto your scanner, press copy button "
Hey Kitty, can I do that?LOL Where abouts might I find DVDX?
Yes, DVDx is nice and interest solution but the result is not good or the best. The video quality is more poor then thru TMPGEnc, also subtitles looks very very poor if u r using DVDx or similar products. For putting subtitles is better to use VirtualDub. It means SMARTRIPPER -> DVD2AVI -> VFAVI frameserving -> VirtualDub with loaded subtitles -> Frameserving -> TMPGEnc -> VideoCD.
It is easy, isnīt it?
Condor -
Easy???? Says who? I found the DVDX. I know quality is important, but I just want to see how it all works, so I can actually complete one. if ya know what I mean, then I will go for quality!
for normal dvd ripping, smartripper->dvd2avi->tmpgenc->nero is quite easy....it's gets pretty routine once you get the hang of it....just knowing when to force film, use the filters, etc. can take a little bit longer...but that's not usually too big of a problem
Well I will try to follow your directions, but I will be sure to keep you in mind when I get ready to go for quality!
Sefy's guide is the way to go. Easy and good results to boot!!!I dont even mess with filters and still get decent quality. Good Luck! :D
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
TDK DVDR840G wont read anything after tryin to remove possible virus
By kemet in forum DVD & Blu-ray RecordersReplies: 9Last Post: 1st Feb 2008, 10:09
