I've had HDHomeRun DVR for five years now and all my captured media files are in .mpg file format.
Just recently setup Jellfyfin and it captures media files in a .ts format.
Frankly, I am not well versed in difference, and even renamed the .ts file to .mpg and it played with no difference.
I thought about converting the new .ts files into a .mpg file format so that all my media is in one file type. Perhaps a bit OCD on my part.
But the conversion process seems to take awhile and I am not sure the effort is worth it. Jellyfin does not have a means to directly capture them as .mpg files.
Can someone shed some light on the big difference and is conversion worth it?
Rename
Video Transport Stream (.ts):
Purpose:
TS files are a container format for storing video and audio data, often used in broadcasting and streaming applications.
Compression:
TS files typically use MPEG-2 video compression.
Examples:
You might encounter .ts files when dealing with DVDs, Blu-ray discs, or streaming video content.
Really no need to "convert" wasting time and quality. Why not select one of your .ts files and post a full MediaInfo file report in text mode not image mode.
https://mediaarea.net/en/MediaInfo/DownloadLast edited by netmask56; 1st Apr 2025 at 00:06.
How do I burn an .MPG file to CD? SVCD.
By shampistols69 in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2024, 14:38 -
How to convert an mkv file to an mpg file or an mpeg file losslessly?
By cthane in forum Video ConversionReplies: 2Last Post: 11th Mar 2024, 16:52 -
Broadcasting PC display via RF modulator/HDHomeRun
By itm2 in forum Newbie / General discussionsReplies: 16Last Post: 16th Oct 2023, 11:47 -
Mac turns itself off randomly while using Jellyfin
By Kal-El in forum MacReplies: 4Last Post: 8th Mar 2023, 23:41 -
[HELP] Corrupt MPG file
By Knalpiep in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2023, 03:36
