I'm spending a lot of time encoding with Handbrake. What fairly inexpensive store PC could I get for doing it. I'd like to just put it upstairs and let it do its thing. That way it would free my regular PC that I'm using for it now for better things. I can find a keyboard and have a monitor and mouse so I was hoping it wouldn't cost too much. Yes I realize storage is cheap, but would like to try this route for now.
What would be my options?
Results 1 to 23 of 23
If it's just for encoding try to find a used PC at local shop. There are several in my area.
Perhaps a relative has one they aren't using anymore.
Those mini-PCs look pretty good too. -
I just took a look at your computer specs. It shows an RTX 4070 Super. Are you using that to encode?
Don't get a mini pc,they have very low cpu power and usually come with 4gb of ram.
How about something like this: Lenovo ThinkCentre M920s 10SJ003WUS Desktop Computer - Core i5 i5-8500 - 16 GB RAM - 256 GB SSD
https://www.amazon.com/Lenovo-ThinkCentre-10SJ003WUS-Desktop-Computer/dp/B08YKBKDKK/re...s%2C127&sr=1-3 -
Is the price correct $699 for a refurbished PC?
You should find better deals from private people they usually buy their children new PC and don't know what to do with the old ones. At least this is how it is here. -
OK. they wouldn't allow me to see the price in my location. It might be a good deal on condition you can return it and get a refund if you are unhappy with. Amazon gives me this choice on new items but I am not sure if they do this on refurbished items.
I have purchased a couple of refurbished computers from newegg & they have worked well for me.
Take a look at this one. It is a tower not SFF.
https://www.newegg.com/dell-9010-business-desktops-workstations/p/N82E16883161526?Item...9SIAKDCDSN7115 -
I'd avoid an SFF computer for video encoding. They often don't have sufficient cooling for running the CPU at 100 percent for hours on end.
Have you considered or tried different (paid) software than Handbrake (Free)? This might save you buying another PC.
I don't use Handbrake because it made my computer too hot during encoding and I was afraid it might cause damage.
I use HD Video Converter Factory Pro for conversions (With GPU support) and other useful features. You can find discount coupons if you search Google. -
How about a PC with the I5 13500T like this one ?
https://www.amazon.com/HP-ProDesk-400-G9-i5-13500T/dp/B0D82LTGQV/ref=sr_1_26?dib=eyJ2I...wQHuWHUMC&th=1 -
That one is still a sff or small form factor.
They do not cool as well & hard to fit an aftermarket cooler inside.
See if you like this one:
https://www.newegg.com/p/1VK-0001-534S3?Item=9SIAK3JK8H3132 -
Its OK but I heard the later 12th and 13th gen CPU's are better which is why I chose the last one, but If I can find a larger case one like the one you chose with a 12th or 13th gen CPU that would be great.
newegg doesn't have any tower refurbs above 10th gen.
Even those are more than the last Amazon one you posted. -
I found this, looks really good for the price.
https://www.amazon.com/dp/B0BNNYWRVT/?coliid=IENC7L0CEGFZF&colid=8INAD9ZLRSAL&psc=1&re...v_ov_lig_dp_it
Handbrake
By Prahlad in forum SubtitleReplies: 2Last Post: 14th Jan 2025, 04:43 -
Encoding with Handbrake
By BlurayHD in forum Newbie / General discussionsReplies: 14Last Post: 24th Aug 2024, 12:48 -
Handbrake for Windows 7
By DaveB69 in forum Video ConversionReplies: 18Last Post: 30th Aug 2023, 02:04 -
Handbrake 1.40
By pepegot1 in forum EditingReplies: 7Last Post: 14th Aug 2021, 16:51 -
Help choosing an inexpensive digital camcorder.
By nopEda in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2020, 15:16
