I'm using Subtitle Edit to put ASS and SRT subtitles on my movies. However getting consistent with them seems impossible. I tried locating them at the same point such as 960,790, but it doesn't always put them in the same place. They are 1080 movies BTW, so to center them always use 960, but height seems to be the issue most of the time.
Can I use the width of the image to locate them ? Say I had 48 font subs and I wanted to locate the them say at 60-70 above the bottom black bar. Would that work accordingly to the width of the film ?
Well.. SRT and ASS are two completely different format of subtitles. SRT can't be stylized nor precisely positioned, while with ASS you have a complete control on WHERE and HOW.
With the ASS format you can set the anchor position of the subtitles relative to the video (TOP/BOTTOM/RIGHT/CENTER/LEFT) and even the distance in pixel from every border. I use KaiNote for my subtitles (since it has styles collections, an amazing feature subtitle edit doesn't have, sadly).. and it's very very easy to set those parameters with it. -
A few players support \pos tags in SRT files. For example:
MPCHC, MPCBE, and PotPlayer support this.Code:1 00:00:01,000 --> 00:00:2,900 {\pos(200,150)}200,150 is about the center of the frame, 2 00:00:03,000 --> 00:00:4,900 {\pos(200,150)}regardless of the frame size.Last edited by jagabo; 28th Mar 2025 at 15:37.
Black bar/cropping at top of screen while using Panasonic DMR-ES15?
By oblivionaccess in forum Capturing and VCRReplies: 1Last Post: 28th Mar 2025, 16:49 -
Add a black bar on video to mask the area without trimming
By loninappleton in forum EditingReplies: 52Last Post: 17th Dec 2024, 02:44 -
Lots of vertical black and white bar artifacts on the DVD
By killerteengohan in forum RestorationReplies: 5Last Post: 8th Dec 2024, 19:48 -
Tool to locate and OCR hard-coded subtitles in MKV/MP4 Files?
By EmmB in forum SubtitleReplies: 1Last Post: 6th May 2022, 19:10 -
FFMpeg Black bar Crop Command
By Daringbaaz in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2020, 12:48
