I previously asked about this on DigitalFAQ, though I haven't received a solution as of yet. I'm using a Panasonic NV-SV1 (a Japanese VCR) and an I-O Data GV-USB2. I've recently acquired an ES15 which I'm incorporating into my workflow. I hook my VCR into the line 1 port of the ES15 with a set of S-Video and RCA audio cables, and hook the ES15 into my capture device with an additional set of S-Video and RCA audio cables. I'm using VirtualDub 1.10.4 for capture, which is set up in accordance to sanlyn's guide on DigitalFAQ.
When my ES15 is connected, there's a small amount of cropping (or masking?) at the top of the screen, about 2 pixels in depth. It does not squish the image, rather it cuts off 2 lines of information from the top of the video. This cropping doesn't appear when I connect the VCR directly into the capture device. I've tried capturing multiple tapes and the same issue has occurred for all of them.
My VirtualDub screen with the ES15 connected vs. without the ES15.
RAW capture with ES15 vs. without ES15.
The same captures after post-processing through Hybrid, again with ES15 vs. without ES15.
Any ideas what might be causing this? Perhaps it's a setting in the ES15 itself?
That is probably a by-product, or side-effect of the TBC itself.
Just a guess (I don't have one to know for sure)
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum Capturing and VCRReplies: 460Last Post: 20th Aug 2025, 18:57 -
Panasonic DMR-ES15 - Macrovision Overexposure
By ENunn in forum RestorationReplies: 2Last Post: 25th Nov 2024, 20:20 -
Panasonic DMR-ES15 PAL - how to setup for TBC passthrough
By spotty in forum Capturing and VCRReplies: 9Last Post: 30th May 2023, 05:06 -
Panasonic DMR-ES15 Remote Control Issues
By czarship in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Jul 2020, 20:33 -
Panasonic DMR-ES15 DVD Drive Intermittently Works
By alitek12 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jun 2020, 00:15
