Hi thanks for reading. I'm a pretty handy guy but not a DVD technician. Here's my situation. I picked up a used DVD player at a thrift sale today and the disk drawer is not opening. I opened the unit and quickly determined that the disk motor attempts to drop, but doesn't seem to have the power to break away from the upper magnetic disk, therefore the whole eject function fails. When I removed the upper part of the disk housing so that the upper disk is not present, the eject function works normally. I removed the disk carrier unit and inspected for any abnormalities but found nothing unusual.
I'm not sure if the rubber drive belt is slipping when it tries to initiate the drop down of the motor breaking the bond with the upper magnetic disk.
Wondering if the belt is stretched since it drives the whole sequence. Any help is appreciated.
Sounds like you need a drive belt.
Sounds like a defect Drive Belt, you can try to force unlock with a paper clip and chage the drive belt without opening the complete DVD
My two Philips Blu-ray players do this as well... Where is a good source for drive belts?
I have a PC with a typical desktop optical drive that does the same thing,
for the same reason. My solution is to always keep a disk in there, then it opens when I want it to.
You just have to remember to put a disk back in after you open it and take out
the one you just used -
Just search "Optical drive belts"
Amazon,Walmart,Newegg,& ebay have assortments & some multiple individual sizes.
This site is in the UK.I have NEVER used them.
They have individual sizes. The cost with shipping may be prohibitive.
http://www.gbaudio.co.uk/data/dvdbelts.htm
SMPlayer 24.5.0 Not Working Properly
By brispuss in forum Software PlayingReplies: 5Last Post: 14th Oct 2024, 10:08 -
AmarecTV isn't working properly
By ElmoRocks05 in forum Capturing and VCRReplies: 19Last Post: 3rd Nov 2023, 03:04 -
Can't find a working program to properly reencode a DVD video.
By Hajker in forum Newbie / General discussionsReplies: 10Last Post: 27th Jan 2023, 09:32 -
Vdub Not Working Properly
By dellsam34 in forum EditingReplies: 2Last Post: 17th Jan 2022, 21:05 -
Subtitle styles not working properly
By Kracov in forum SubtitleReplies: 2Last Post: 3rd Dec 2021, 08:29
