I have a sandisk cruzer 3.0 USB drive. I cant remember how big it is, but it is only giving me 29 gbs of space. I remember it being bigger. I did format to NTFS. How can i retrieve all of my space back and what tool to use to get it? Diskpart?
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
You could reduce the recycle bin size.
Rightclick the recycle bin icon on the desktop and set the size of the USB cruzer to 100MB. -
You could also do a right mouse click and select 'properties' to get more info on that stick.
Extraordinary claims require extraordinary evidence -Carl Sagan -
Probably a bits vs Bytes issue. Here are some of my drives (Right-click "My PC" choose "Manage" then "Disk Management":
[Attachment 86310 - Click to enlarge]
Disk 4 is labelled as 4TB.
Disk 6 is labelled as 16GB.
You can see you don't get all the disk to use; you "lose" ~10%.
My hunch is that your stick is 32GB with ~29 useable. -
You should be able to see what is the size of the disk written on the label. If it is 32Gb then this is the maximum you will get, as Alwyn explained, otherwise it is a fake disc.
Disk (USB or plastic) capacity and the usable space are related but the figure may not align for good reasons:
1. manufacturers often quote Gigabytes as 1,000,000,000 bytes but technically they are 1,024,000,000 bytes.
2. some of the available space is taken up by the format pattern and the partition table and file allocation tables.
Brian. -
You still haven't posted the properties of that stick. Can you do that please? See post #3 for directions or do what Alwyn did and post that here.
Fake sticks can be made to post incorrect data but checking properties is what I do first if I have an issue with a usb stick.Last edited by TreeTops; 27th Mar 2025 at 10:37.
Using a USB Capture HDMI Gen 2 with VirtualDub2 & no codecs are showing
By OdjnRyu in forum Newbie / General discussionsReplies: 0Last Post: 9th Nov 2023, 17:46 -
Sandisk iXpand/Go USB Drive help.....
By SIRCOOKS in forum Off topicReplies: 1Last Post: 11th Mar 2023, 02:35 -
Toast is saying not enough disk space (how can that be?)
By kubrick74 in forum MacReplies: 10Last Post: 27th Aug 2022, 23:47 -
Showing full path on Subtilte Edit window
By robena in forum SubtitleReplies: 0Last Post: 30th Jul 2021, 08:44 -
MPC-HC (preferably) - autoplay videos full screen, full screen space
By MadOne in forum Software PlayingReplies: 7Last Post: 9th Oct 2020, 11:23
