Hi all,
Please advise how to make text popin, word to word, according to speech file?
Regards
It depends on your editing software. You can achieve word-by-word text pop-in synced with speech using keyframe animation or automated tools.
What soft do you use? -
In Shotcut you can use the Text: Rich filter with manual keyframing for each word. Maybe this will be helpful https://www.youtube.com/watch?v=tE_ZTYI5g1w
Hi,
Thanks for your advice and link.
What I expect to do is;
1) I already have a text file
2) Using the text file I create a speech file (text to speech)
3) I need the text running in step with the speech. I can add speech and text to the video. But they are NOT in step. i.e. the text popup in time together with speech, word by word.
It can be done. I saw it on video online. I'm now searching how to make it?
Regards
Edit-1
The text is popup in lines. The word glows in step with the speech narration. It can be done. I saw it on video online.
What I can achieve now is the text moving up on screen in lines.
Edit-2
Hi all,
Below is a video showing text popup while talking;
https://www.youtube.com/watch?v=3kl66kZSNVI
But I need the text popup while the audio file playing on that section of the video !!!
Premiere pro is Adobe package. What will be its alternative in Open Source? I'm now running Shotcut and OpenShot.
ThanksLast edited by satimis; 28th Mar 2025 at 06:04. Reason: further explanation
VSDC Video Editor make scrollinbg text only appear in section of scene
By OldNick in forum Newbie / General discussionsReplies: 0Last Post: 3rd Oct 2022, 17:16 -
Does it exist some app or software to make animated text?
By Chemist116 in forum Newbie / General discussionsReplies: 9Last Post: 11th May 2022, 19:25 -
In VSDC FREE, How to pop up random words in random screen locations?
By EricBalir in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2021, 10:10 -
search Avisynth Expert to make Slideshow with template and Text over Image
By danilo in forum EditingReplies: 1Last Post: 7th Jun 2021, 11:34 -
Easier ways to make split screen videos?
By SixStringSW in forum EditingReplies: 5Last Post: 15th Jan 2021, 13:31
