  1. Hi all, most probably this is an easy one.
    Iam making a cDVD using DVDit SE, no problem there. I have clicked the include DVD player option and burnt the CD.
    Now when i run it on another machine the winDVD built in player splash screen comes up telling me that the player is an unregistered evaluation copy. My question is what do i need to do to incorporate a full working player instead of the winDVD trial one. Also can I use a different make player instead of the winDVD one.
    Ive searched everywhere for an answer but no help either from Sonic or winDVD.
    Thanks in advance.
    ps. I want to use a built in player just in case the end user does not have one installed on their windows system.
  2. There are several really good freeware media players available. Have you tried any of those? If your interested then check 'tools' on the left or goto Doom9.org
  3. I had same issue in the past.
    In DVDit! there is a option "Include player in the DVD". It looks like that you have left this as "true".
    Reset this option, create new DVD and you will have "pure" movie DVD - that one you will be able to play on ANY DVD player.
