Since nothing comes easy in life, this is the strange effect I'm getting when capturing directly from a Samsung camcorder. The problem persists when I play tapes from it.
This wobbly effect is not there when connecting the camcorder to a pretty nice Speaka upscaler via composite. The upscaler outputs HDMI. Sadly I don't have a CRT available where I currently am.
I'm doing the capturing with Amarec, using the most standard settings, I'd say. 25fps (since it's PAL), no interlacing, no effects, etc.
Are you familiar with this problem?
You need a Line Time Base Corrector. You can pass the signal through an old Panasonic ES10 or ES15 to fix the horizontal wobble.
Agree you need a line TBC either in a VCR that has one or ES10 for the wobble part, but The rolling flicker is also kind of interesting. That could potentially represent a "ground loop". Usually the fix for that is making sure all devices are plugged into the same power strip and not into multiple outlets in the same room.
I was not aware of the potential need for a TBC.
When I connect my camcorder to my Speaka upscaler and then capture the HDMI signal, I get none of the wobbliness you can see in the attached video. Why is that? Is the upscaler doing some postprocessing I'm not aware of?
Is this a typical problem when capturing directly from a camcorder? -
@jagabo, thanks a lot for your input.
I obtained a rather good result by using the upscaler plus an HDMI capture device. I'll need to consider whether getting one of those ES10's is worth it, or I should rather send the 8mm tapes to some service. It's 3 of them after all.
Video/Audio sync problems with Hauppauge USB-Live2 & Vdub
By liddle in forum Capturing and VCRReplies: 34Last Post: 30th Dec 2025, 08:15 -
Oversharpened image with Hauppauge USB-Live2? How to fix?
By AlvinusDeDiaspar in forum Capturing and VCRReplies: 8Last Post: 20th Mar 2025, 17:29 -
linux capturing apps for Hauppauge USB-Live2
By chconnor in forum Capturing and VCRReplies: 15Last Post: 12th Nov 2024, 21:58 -
Hauppauge USB-Live2 Win10 BSoD + video quality issues
By Blenzo480 in forum Capturing and VCRReplies: 5Last Post: 3rd Nov 2024, 18:59 -
Which Hauppauge USB-LIVE2?
By Leanoric in forum Capturing and VCRReplies: 14Last Post: 22nd Jan 2024, 04:09
