Results 1 to 26 of 26
  1. Hi,
    I'm trying to install playready proxy and play ready proxyapi from ThatNotEasy I wonder if any of you have made it wrk successfully please ?
    my PRPApi is launching fine, but my PRP edge plugin don't make any call on the API.
    Here is my PRP plugin screen
    [Attachment 86164 - Click to enlarge]
    Thanks a lot for any help
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Seems that extension is still kinda buggy. Hope they fix it. Here's what worked for me without bothering too much. There are 2 directories
    - PlayReadyProxy-API-main => the local api
    - PlayReadyProxy-main => the extension
    Unpack them both. In the local api folder:
    - rename the env and config like their git tells you to do
    - copy in that folder (near the app.py) the prd file. Mine is called: "your_prd_file.prd"
    - then go to config.ini and change
    [CDM]
    DEVICE_FILE = device/ # DEVICE FILENAME
    DEVICE_NAME = # DEVICE NAME
    to
    [CDM]
    DEVICE_FILE = your_prd_file.prd
    DEVICE_NAME = your_prd_file.prd
    - create the file "APIKEY.json" (double check the right extension, do not create "APIKEY.json.txt"). Then in that file paste this content
    [{"apikey":"secret"}]
    - start their flask server like their git tells you to do and it runs on
    * Running on http://127.0.0.1:1337
    Now in the other extension folder.
    - go to config folder and open "local.json" . Change
        "security_level": "",
        "host": "",
        "secret": "",
        "device_name": ""
    to
        "host": "http://127.0.0.1:1337",
        "secret": "secret",
        "device_name": "your_prd_file.prd"
    - then install the extension on edge
    - open the addon menu, make sure "enabled" is checked. Go to remote cdm > choose config and pick the previously edited "local.json" file.
    While testing the addon on
    https://reference.dashif.org/dash.js/v4.4.0/samples/drm/playready.html
    I had to refresh 2 times to get both set of keys (video+audio) and it worked.
    [Attachment 86173 - Click to enlarge]
    N_m3u8DL-RE "https://media.axprod.net/TestVectors/v7-MultiDRM-MultiKey-MultiPeriod/Manifest.mpd" --key 2d6e938760ca4145aec2c40837b4b026:42d0bff1b60f7be49f17d603484d0cb9 --key 8b029e51d56a44bd910fd4b5fd90fba2:c889cca25eb30b3b128eb834ea4da4fa -M format=mkv
  3. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    [CDM]
    to
    [CDM]
        "host": "",
        "secret": "",
        "device_name": ""
    to
        "secret": "secret",
    May I ask how to use this program?
    https://github.com/ready-dl/csplayready
  4. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Many thx for this tutorial
  5. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    It's a C# implementation. It's not an addon. It even explains you the steps in the readme git section. If you can handle pyplayready, you can handle the C# alternative. If you don't know about scripts, then you can stick only to the addons.
    No problem
  6. I had done all step
    but It seems not query the api.
    [Attachment 86198 - Click to enlarge]
    tried under windows and same thing. do anyone have a clue on what I made wrong please ?
  7. Originally Posted by evangelle View Post
    I had done all step
    Have you fond solution?
  8. nxhda
    Sep 2022
    try use local.json
    discord nxhda
    Jun 2025
    France
    Hello,
    Thanks for this tutorial!
    I've done everything correctly, I don't get any error messages, and yet it's not working. Any ideas?
    [Attachment 87639 - Click to enlarge]
    My PlayReady-API -> config.ini :
    [CDM]
    DEVICE_FILE = device/lg_electronics_inc_lg_webos_tv_msd93xbg_sl3000.prd
    DEVICE_NAME = LG
    My PlayReady-API-> APIKEY.json :
            "username": "test",
            "apikey": "test_99c036381a6736de600f61c07a"
    My PlayReady -> config -> local.json :
        "security_level": "3000",
        "secret": "test_99c036381a6736de600f61c07a",
        "device_name": "LG"
    Did I miss something, please?
    Thanks in advance
  10. larley the king of video decryption! thank you so much mate for your work. amazing
    just little tip: from PR github page on chrome section you write 'download zip'
    we have just xpi file, for FF. anyway it's easy to extract all content with wrar or 7zip
    loaded extension on chromium browser i get this error 'background.scripts' requires manifest version of 2 or lower
  11. Originally Posted by whs912km View Post
    just ignore it
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  12. yea, right. but why this error from this new extension?
    or this error is with chromium browser only and no error with FF browser?
    also tried to edit manifest version 3 to version 2 but my browser can't load extension, with manifest version 2
    just out curiosity...!
  13. Originally Posted by whs912km View Post
    Among Chromium browsers, I think it is only going to work on Microsoft Edge. In Ungoogled Chromium there is no PlayReady CDM displayed in chrome://media-internals/
    I tried implementing some PlayReady-to-ClearKey hook with LLM assistance, but it doesn't work yet and I have no idea how to pass information to jsplayready from content script. Maybe larley can help.
    (function () {
      const originalRequest = navigator.requestMediaKeySystemAccess;
      navigator.requestMediaKeySystemAccess = async function (keySystem, supportedConfigurations) {
            if (["com.microsoft.playready.recommendation", "com.microsoft.playready.recommendation.3000", "com.microsoft.playready.hardware", "com.microsoft.playready", "com.youtube.playready"].includes(keySystem)) {
          const realKeySystem = "org.w3.clearkey";
          // Sanitize configurations for compatibility with ClearKey
          const modifiedConfigs = supportedConfigurations.map(config => {
            const sanitized = { ...config };
            sanitized.videoCapabilities = (config.videoCapabilities || []).map(cap => {
              const { robustness, ...rest } = cap;
              return rest;
            sanitized.audioCapabilities = (config.audioCapabilities || []).map(cap => {
              return rest;
            // Optional: sanitize other fields like distinctiveIdentifier, persistentState, etc.
            return sanitized;
          const access = await originalRequest.call(navigator, realKeySystem, modifiedConfigs);
          const originalCreate = access.createMediaKeys.bind(access);
          const wrappedAccess = {
            keySystem,
            getConfiguration: () => access.getConfiguration(),
            createMediaKeys: async () => {
              const realMediaKeys = await originalCreate();
              return createWrappedMediaKeys(realMediaKeys);
          return wrappedAccess;
        return originalRequest.call(navigator, keySystem, supportedConfigurations);
    function createWrappedMediaKeys(realMediaKeys) {
      const originalCreateSession = realMediaKeys.createSession.bind(realMediaKeys);
      realMediaKeys.createSession = function (...args) {
        const realSession = originalCreateSession(...args);
        return new Proxy(realSession, {
          get(target, prop) {
            if (prop === "generateRequest") {
              return async (initDataType, initData) => {
                console.log("[CustomKeySystem] generateRequest", { initDataType, initData });
    	    console.log(Object.keys(initData));
                if (initDataType == "cenc") {
    	      const data = new Uint8Array(initData);
                  //let pssh = Pssh(initData);
    	      console.log(uint8ArrayToString(data));
                  //const a = uint8ArrayToString(initData);
                  //console.log(Object.keys(initData));
                  return target.generateRequest("keyids", initData);
                return target.generateRequest(initDataType, initData);
            if (prop === "update") {
              return async (response) => {
                console.log("[CustomKeySystem] update", response);
                // {"keys":[{"kty":"oct","alg":"A128KW","kid":"nrQFDeRLSAKTLifXUIPiZg","k":"FmY0xnWCPCNaSpRG-tUuTQ"}]}
                return target.update(response);
            return typeof target[prop] === "function"
              ? target[prop].bind(target)
              : target[prop];
      return realMediaKeys;
  14. background and content script communicate through a message proxy that converts one type of event to another and adds a unique id to each one to track which have arrived and which haven't. It's a true pain but also the only way possible.
    async function processMessage(detail) {
        return new Promise((resolve, reject) => {
            chrome.runtime.sendMessage({type: detail.type, body: detail.body}, (response) => {
                if (chrome.runtime.lastError) {
                    return reject(chrome.runtime.lastError);
                resolve(response);
    document.addEventListener('response', async (event) => {
        const { detail } = event;
        const responseData = await processMessage(detail);
        const responseEvent = new CustomEvent('responseReceived', {
            detail: detail.requestId.concat(responseData)
        document.dispatchEvent(responseEvent);
    From PlayreadyProxy2
    const playready_device = new Device(Utils.base64ToBytes(device_b64));
    const cdm = Cdm.fromDevice(playready_device);
    const licenseChallenge = cdm.getLicenseChallenge(wrmHeader, rawRevLists, version);
    const returned_keys = cdm.parseLicense(decodedLicense);
    const keys = returned_keys.map(key => ({ k: utils.bytesToHex(key.key), kid: utils.bytesToHex(key.key_id) }));
    Jun 2025
    France
    Originally Posted by larley View Post
    Hello, and thank you very much for your help!
    I tried PlayreadyProxy2 on Edge and Chrome, but it doesn't seem to be working.
    Is this a PlayreadyProxy update?
    Do I need the same configuration as for PlayreadyProxy (server, etc.), or just the .prd file and do roughly the same thing as for WidevineProxy2?
    Thanks in advance
    Sincerely,
    Yanis
  16. everything is the same as with widevineproxy2 except that there will never be remote cdm support. and no it doesn't have anything to do with playreadyproxy
    Jun 2025
    France
    Hi,
    Okay, great, thanks for taking the time to answer me. The tool is truly incredible from what I've tested (with WidevineProxy2).
    Now I'm getting an error with WidevineProxy2 or PlayReadyProxy2.
    The video isn't loading (normal), but I no longer have the key. At the bottom of the screen, it says:
    ENGINE_ERROR / ENGINE_DRM_ERROR
    Is this because my .wvp or .prd file is banned?
    Or is it unrelated?
    Thanks in advance.
    EDIT : I dumped my own .wvd and it works again with WidevineProxy2
    But if I want to download content from Canal+, I get the audio, but the video is encrypted.
    I tried with PlayReadyProxy2, but I don't have anything in "Keys," and the video plays normally (even though the extension is enabled).
  18. Originally Posted by yalgerino View Post
    Use Microsoft Edge web browser. Go to edge://flags to enable "Override software rendering list" (to force enable PlayReady DRM if your hardware doesn't support it) and disable "Widevine DRM". I suggested reimplementing the program to not require PlayReady support, but it isn't done yet.
    Jun 2025
    France
    works like a charm !
    Thank you so much for your help!
    And thanks for the work, @larley
  20. Someone else developed the program that I suggested. I made a thread for it.
    Aug 2023
    Turkey
    i have a problem like this
    Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'map')
    and
    Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'textContent')
    Bud on this test side i get the keys
    i thnink thad teh browser not supported playready or samthink like this i think wee need godo brower ?
    any help welcome !
  22. Member
    Aug 2023
    Ukraine
    Hello. Question I have a *.prd version 2 file (SL3000) - is it possible to convert it to *.prd version 3?
  23. Originally Posted by nadya86 View Post
    As our Ukrainian boxer Oleksandr Usyk said the phrase "Don't push the horses" before his rematch with Daniel Dubois, or as you call it "Don't rush". This site doesn't give anyone anything just like that. You have to work hard, study the logic, functions, how it works, and then transfer the functionality to any programming language.
    [...] Create your own, you will appreciate it more!
  24. Member
    Aug 2023
    Ukraine
    So you're quoting me, that's good)! Well done!!! But you removed the very essence of my message!!!
    I finally finished my MEGA Project on PowerShell scripts, which does not contain a single line of python, everything works. There were some bugs in the scripts, but during testing I fixed them. I want to thank your community for helping me understand the Widevine system, now I will write scripts to decode videos from PlayReady
    Well done. Could you post it for others to use?
    As our Ukrainian boxer Oleksandr Usyk said the phrase "Don't push the horses" before his rematch with Daniel Dubois, or as you call it "Don't rush". This site doesn't give anyone anything just like that. You have to work hard, study the logic, functions, how it works, and then transfer the functionality to any programming language. In my case, it was "PowerShell", which managed to bring my thoughts to life. And I want to tell you that my project is not one script, but a dozen of them, which work in pairs and pass variable data to each other. If you really want to repeat my actions, then I will give you some advice. First, read in my thread where other people gave me advice that I should also study. And move in that direction. If you really want to do this, I will guide you as much as possible, and suggest what and how to implement. If you just want someone to give you their project that I spent almost a year studying and programming, then this will not happen. Create your own, you will appreciate it more!
