Hi
please be patient:
# <--here a poor cat ###
So my target is 25fps, output format: MXF xdcamhd422 profile, 50i interlaced
whit a filter to avoid aliasing ad artifacts due to conversion.
https://www.swisstransfer.com/d/45e6c1bf-f64c-4af1-a73b-c96718efe466
My empirically script (drone7.avs):
and then the transcoding process is:Code:Import("c:\santiag.avsi") BSVideoSource("v:\25fpsDrone.mp4") #ConvertToYV24() FrameRateConverter(50000,1000, preset = "faster") santiag(strh=2, strv=1, type="nnedi3", nns=0, threads=0, nsize=6, halfres=false, scaler_post="Spline36Resize") ConvertToYUY2(interlaced=false) assumetff().separatefields().SelectEvery(4, 0, 3).weave() #interlace Prefetch(8)
ffmpeg2025.exe -v quiet -stats -y -i v:\drone7.avs -an -pix_fmt yuv422p -f rawvideo - | v:\ffmbcX642017.exe -threads 12 -s 1920x1080 -r 25 -y -f rawvideo -pix_fmt yuv422p -i - -i "v:\10 - Traccia 10_HDavs.wav" -tff -target xdcamhd422 -an -ac 4 v:\drone5.mxf -newaudio -acodec pcm_s24le -ar 48000
processing is slow7 fps
this my results:
https://www.swisstransfer.com/d/c69054c8-c470-48c5-9d9e-5d8823c6fcbc
I try to replace emask with santiag to see if I can see better results, or I'm wrong? in any case can the script be better corrected?
let me know your opinion cat
thanks thanks
Results 1 to 26 of 26
Use RIFE
Code:LWLibavVideoSource("25fpsDrone.mp4") #your progressive 25fps source RGB=z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:auto:auto:limited=>rgb:same:same:full") # convert to RGB floats RIFE=RGB.RIFE(gpu_thread=1, model=11, fps_num=50000, fps_den=1000, sc=true, sc_threshold=0.3) # motion interpolation using model 11 YV12=RIFE.z_ConvertFormat(pixel_type="YUV420P8", colorspace_op="rgb:auto:auto:full=>709:same:same:limited") # convert back to YV12 interlace=YV12.separatefields().selectevery(4,0,3).weave() #interlace prefetch(8) return interlaceLast edited by Sharc; 17th Mar 2025 at 03:40.
Improvement: Select model=12 in the script above. It seems to produce less annoying interpolation artefacts, but is slower. You can experiment yourself to find the "best" model ....
Code:LWLibavVideoSource("25fpsDrone.mp4") #your 25p source RGB=z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:auto:auto:limited=>rgb:same:same:full") # convert to RGB floats RIFE=RGB.RIFE(gpu_thread=1, model=12, fps_num=50000, fps_den=1000, sc=true, sc_threshold=0.3) # motion interpolation using model 12 YV12=RIFE.z_ConvertFormat(pixel_type="YUV420P8", colorspace_op="rgb:auto:auto:full=>709:same:same:limited") # convert back to YV12 interlace=YV12.assumeTFF().separatefields().selectevery(4,0,3).weave() #interlace prefetch(8) return interlaceLast edited by Sharc; 17th Mar 2025 at 04:27.
Sharc cat for kindness:
my target is encode to 422 (xdcamhd422) so I try this:
need I to change the YUV420P8 parameter?Code:BSVideoSource("v:\25fpsDrone.mp4") #your 25p source RGB=z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:auto:auto:limited=>rgb:same:same:full") # convert to RGB floats RIFE=RGB.RIFE(gpu_thread=1, model=12, fps_num=50000, fps_den=1000, sc=true, sc_threshold=0.3) # motion interpolation using model 12 YV12=RIFE.z_ConvertFormat(pixel_type="YUV420P8", colorspace_op="rgb:auto:auto:full=>709:same:same:limited").convertToYUY2(interlaced=false) # convert back to YV12 interlace=YV12.assumeTFF().separatefields().selectevery(4,0,3).weave() #interlace return interlace prefetch(8)
and is there a more speed model? -
For YUV422 output:
Code:LWLibavVideoSource("Drone\25fpsDrone.mp4") RGB=z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:auto:auto:limited=>rgb:same:same:full") RIFE=RGB.RIFE(gpu_thread=1, model=12, fps_num=50000, fps_den=1000, sc=true, sc_threshold=0.3) YV16=RIFE.z_ConvertFormat(pixel_type="YUV422P8", colorspace_op="rgb:auto:auto:full=>709:same:same:limited") interlace=YV16.assumeTFF().separatefields().selectevery(4,0,3).weave() prefetch(8) return interlaceTry all models, one by one, and tell us your findings....and is there a more speed model?Last edited by Sharc; 14th Apr 2025 at 18:28.
model 12 seems good, but maybe, I need to apply a little, advanced, antialiasing line.
However:
let explain the cat
This is my source:
https://www.swisstransfer.com/d/5eaa2e33-8ac3-4f34-aea4-f14062ca14f1
it's my low quality drone video
wow, 25P
My target is get an interlaced version of it, 50i, transcoded ok, minimizing artifacts.
https://www.swisstransfer.com/d/f845b80a-3039-469a-beb5-2093d517f8c3
that seems not bad but there are some little artifacts in certain point.
However I don't like a lot to use Da*****R*****ve, if possible, and I try to transcode with an avisynth script.
So what is the correct way to optimize this process?Last edited by marcorocchini; 8th Aug 2025 at 07:15.
I am not aware of any interpolator which does NOT produce any artifacts.
RIFE is sharper, preserves much more details and has much less interpolation artifacts (see for example the TV antenna on the roof) than your Resolve version.
Watch the separated fields of the 2 variants interleaved and you will easily see the differences.Last edited by Sharc; 16th Apr 2025 at 17:47.
I cat understand
but the result of the only rife seems a little too sharp for me, is there perhaps some rife models that integrates something like greater antialiasing?
The preservation of details, however important, risks becoming excessive if this implies a little too much "noise" on images that have a low quality origin like my drone, or images coming from low level cameras whose electronic signal processing is not at low intermodulation, in this case, at this point, it seems more correct to "hide" details during transcoding even if overall the image is slightly softer, rather than maintaining high details but at the same time high crudeness and crispening -
The one which pleases your eyes most.
If you want to reduce "crispiness" and aliasing you can try on progressive video something like
Code:LWLibavVideoSource("25fpsDrone.mp4") RGB=z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:auto:auto:limited=>rgb:same:same:full") RIFE=RGB.RIFE(gpu_thread=1, model=12, fps_num=50000, fps_den=1000, sc=true, sc_threshold=0.3) YV12=RIFE.z_ConvertFormat(pixel_type="YUV420P8", colorspace_op="rgb:auto:auto:full=>709:same:same:limited") # convert back to YV12 mask=masktools2_mt_edge(YV12).grayscale() blur=YV12.blur(1.0) res=overlay(YV12, blur,mask=mask,opacity=1.0,mode="blend") interlace=res.assumeTFF().separatefields().selectevery(4,0,3).weave() #interlace prefetch(8) return interlaceLast edited by Sharc; 17th Apr 2025 at 09:45. Reason: typo
sharc cat please I need that: the script should present an output YUV422
Need I to add at the end of the script the converttoYUY2(interlaced=false) ? -
No.
I already told you in post#5 how to do it. So here again:
Code:LWLibavVideoSource("25fpsDrone.mp4") RGB=z_ConvertFormat(pixel_type="RGBPS", colorspace_op="709:auto:auto:limited=>rgb:same:same:full") RIFE=RGB.RIFE(gpu_thread=1, model=12, fps_num=50000, fps_den=1000, sc=true, sc_threshold=0.3) YV16=RIFE.z_ConvertFormat(pixel_type="YUV422P8", colorspace_op="rgb:auto:auto:full=>709:same:same:limited") YV16=YV16.santiag(3,3) mask=masktools2_mt_edge(YV16).grayscale().blur(0.5) blur=YV16.blur(1.0) res=overlay(YV16, blur,mask=mask,opacity=1.0,mode="blend") interlace=res.assumeTFF().separatefields().selectevery(4,0,3).weave() prefetch(8) return interlaceLast edited by Sharc; 18th Apr 2025 at 04:00. Reason: File attached
Sharc I think to have a problem with all version of Avisynth greater than R3661: I use Mainconcept Totalcode to encode the .avs but the versions that support RIFE wont load the audio part of the .avs
I don't know the reason but I force to use, at leat for the moment, Avisynth R3661 and RIFE is not working.
So I try to replace RIFE with the smoothFPS2.avsi:
function SmoothFPS2(clip source, int num, int den) {
super = MSuper(source, pel=2, hpad=0, vpad=0, rfilter=4)
backward_1 = MAnalyse(super, chroma=false, isb=true, blksize=32, searchparam=3, plevel=0, search=3, badrange=(-24))
forward_1 = MAnalyse(super, chroma=false, isb=false, blksize=32, searchparam=3, plevel=0, search=3, badrange=(-24))
backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3)
forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3)
backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, searchparam=0, search=3)
forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, searchparam=0, search=3)
MBlockFps(source, super, backward_3, forward_3, num, den, mode=0)}
that seems work not very bad.
but I'm not able to modify the script to use it instead of Rife, what can I do? -
Your posted source file '25fpsDrone.mp4' has no audio track, btw.
But anyway, here the RIFE replacement as you wish:
Code:LWLibavVideoSource("25fpsDrone.mp4") YV16=z_ConvertFormat(pixel_type="YUV422P8", colorspace_op="709:auto:auto:limited=>709:same:same:limited") YV16=SmoothFPS2(YV16,50000,1000) YV16=YV16.santiag(3,3) mask=masktools2_mt_edge(YV16).grayscale().blur(0.5) blur=YV16.blur(1.0) res=overlay(YV16, blur,mask=mask,opacity=1.0,mode="blend") interlace=res.assumeTFF().separatefields().selectevery(4,0,3).weave() #interlace prefetch(8) return interlace ################# FUNCTION #################################################### function SmoothFPS2(clip source, int num, int den) { super = MSuper(source, pel=2, hpad=0, vpad=0, rfilter=4) backward_1 = MAnalyse(super, chroma=false, isb=true, blksize=32, searchparam=3, plevel=0, search=3, badrange=(-24)) forward_1 = MAnalyse(super, chroma=false, isb=false, blksize=32, searchparam=3, plevel=0, search=3, badrange=(-24)) backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3) forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3) backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, searchparam=0, search=3) forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, searchparam=0, search=3) MBlockFps(source, super, backward_3, forward_3, num, den, mode=0)} ############################################################################### -
sharc cat for kindness: seems that the script output is YV16.
Can I get it YUY422 for direct encoding to ffmbc/ffmpeg/totalcode? -
YV16 is YUV 4:2:2 planar. Your YV12 4:2:0 source is converted to YUV 4:2:2 planar in line 2 of the script of post#15.
If you need it interleaved instead of planar you can replace the last line of the script by
This conversion is lossless.Code:return interlace.ConvertToYUY2(interlaced=true)
sharc cat I ask this:
due to the fact I can't use, at the moment, Rife
Does exist an alternative to SmoothFPS2 that do sometimes artifacts? -
I don't understand your question, but RIFE is better than SmoothFPS2 and better than the other mvtools based interpolators I know (like framerateconverter) and better than what you produced with Resolve. "Better" means that it produces less annoying artefacts.
You may google for other alternatives.Last edited by Sharc; 20th Apr 2025 at 16:59.
There are several motion compensated frame rate interpolators like FrameRateConverter(), InterFrame(), SVPflow(), etc.
http://www.avisynth.nl/index.php/External_filters#Frame_Rate_Conversion
Most variations use mvtools. -
Please help the poor cat:
[Attachment 86670 - Click to enlarge]
I would like to "incapsulate" in 1 unique function the 3 lines:
Do I need compile an .avsi file?Code:santiag(2,2) fmask=masktools2_mt_edge().grayscale().blur(0.5) overlay(last, blur(1,0),mask=fmask,opacity=1.0,mode="blend")
But seems it dont workCode:function SantiagComplex(clip c) { santiag(2,2) fmask=masktools2_mt_edge().grayscale().blur(0.5) overlay(last, blur(1,0),mask=fmask,opacity=1.0,mode="blend") }Last edited by marcorocchini; 21st Apr 2025 at 11:02.
What's the purpose?
Didn't test it much, so try below
Call it in the script post#15 (line res=....) likeCode:function SantiagComplex(clip c,int radius,float decrisp) { santiag(c,radius,radius) mask=masktools2_mt_edge(c).grayscale().blur(0.5) overlay(c, blur(c,decrisp),mask=mask,opacity=1.0,mode="blend") }
And eventually try:Code:res=SantiagComplex(YV16,2,1.0)
Code:LWLibavVideoSource("D:\Temp\marcorochini - the cat\Drone\25fpsDrone.mp4") z_ConvertFormat(pixel_type="YUV422P8", colorspace_op="709:auto:auto:limited=>709:same:same:limited") SmoothFPS2(last,50000,1000) SantiagComplex(last,2,1.0) assumeTFF().separatefields().selectevery(4,0,3).weave() #interlace ConvertToYUY2(interlaced=true) #for 422 interleaved output prefetch(8) ########### FUNCTIONS ######################################################################################### function SmoothFPS2(clip source, int num, int den) { super = MSuper(source, pel=2, hpad=0, vpad=0, rfilter=4) backward_1 = MAnalyse(super, chroma=false, isb=true, blksize=32, searchparam=3, plevel=0, search=3, badrange=(-24)) forward_1 = MAnalyse(super, chroma=false, isb=false, blksize=32, searchparam=3, plevel=0, search=3, badrange=(-24)) backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3) forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3) backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, searchparam=0, search=3) forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, searchparam=0, search=3) MBlockFps(source, super, backward_3, forward_3, num, den, mode=0)} function SantiagComplex(clip c,int radius,float decrisp) { santiag(c,radius,radius) mask=masktools2_mt_edge(c).grayscale().blur(0.5) return overlay(c, blur(c,decrisp),mask=mask,opacity=1.0,mode="blend") } ############################################################################################################Last edited by Sharc; 22nd Apr 2025 at 06:13.
ah wow seems works
but I wonder:Code:SantiagComplex(YV16,2,1.0)
the 1.0 is the value for blur argument?
In this case, the equivalent of the original line
what should be using the new SantiagComplex function?Code:santiag(2,2)
Yes. This is the blur value for making the video look less sharp and less crispy but still keeping details - as you wanted in post#8. It has nothing to do with santiag.
The script in post#22 does the same as the script in post#15. Only difference is the santiag parameters, and the "incapsulation" of santiag and the edge masked blurring in a new function which you named SantiagComplex() in post#21.
I suggested santiag(3,3) in my earlier posts, you wanted santiag(2,2) in your non-working attempt in post#21. So I changed it to (2,2) in post#22.
The function SantiagComplex(clip c,int radius,float decrisp) as defined at the end of the script in post#22, when called, invokes santiag(radius,radius) plus the edge masked blur(decrisp).
So calling like SantiagComplex(v,2,1.0) means to process the video v with santiag(2,2) and with the edge masked blur(1.0)
Just copy and paste the full script of post#15 or #22 and be done with it. They do the same, with the exception of the santiag parameters which I changed upon your request.
(And once you have RIFE working revert to post#5 or #11).Last edited by Sharc; 22nd Apr 2025 at 16:30.
https://www.swisstransfer.com/d/b1768b03-397c-474e-a63f-5482732633a6
I wonder if is there a new improvement that can more reduce artifacts? even if its necessary usage of new tools
THANKSCode:LSMASHVideoSource("W:\aaa\DJI_0645.MP4") ConvertToYV12(interlaced=false) santiag(3,3) fmask=masktools2_mt_edge().grayscale().blur(0.5) overlay(last, blur(1,0),mask=fmask,opacity=1.0,mode="blend") ConvertToYUY2(interlaced=false)Last edited by marcorocchini; 8th Aug 2025 at 07:16.
Restoring Interlaced master that should have been progressive
By Jan Tokki in forum RestorationReplies: 7Last Post: 20th Jul 2022, 15:30 -
ffmpeg Telecine output is always Progressive, should it be Interlaced also.
By JN- in forum Newbie / General discussionsReplies: 16Last Post: 9th Jun 2022, 20:21 -
Interlaced Artifacts on Progressive Video?
By TheKCVault in forum Newbie / General discussionsReplies: 3Last Post: 28th Apr 2021, 17:52 -
Convert progressive video to interlaced for a DVD
By Mr Magnétoscope in forum Authoring (DVD)Replies: 35Last Post: 2nd Sep 2020, 18:34 -
ffmpeg changes interlaced to progressive
By SF01 in forum Video ConversionReplies: 12Last Post: 30th Mar 2020, 09:51
7 fps
ok cat but there are a recent antialiasing plugin for
