I started capturing Hi8 tapes (from 1992) 10 or 12 years ago and got sidetracked so I stopped. I was originally using a very old version of Premiere Elements 4.0 which, as I recall, was working very well at the time. I recall the captured AVI vids were segmented, with a separate AVI file each time the Sony handycam was originally started and stopped. I may have been using a TVR530 for capture previously but I just don't recall.
As I restarted capturing in past month using WinDV the file segmenting is now solely based on a hard setting in WinDV instead of the handycam users' starting and stopping. Is it possible that older tapes didn't have the auto-segmenting but newer tapes might? Is it based on the TRV320 vs. the TRV530 differences? As everyone does as they start this project, I just want to try and create the best files possible and I kind of liked the auto-segmenting based on recording starts/stops.
Is there better software out there than WinDV today, or a better method than the direct firewire DV transfer?
Any input is much appreciated. Kind regards.
Results 1 to 11 of 11
Thanks.
After some forum searching, it looks like the answer to my original question (individual files created based on the original starting and stopping of recording) is whether or not the original tape was recorded with a digital or analog camera. Even though I'm using the 320 or the 530 digital cameras for firewire capture today, I see a capital letter 'D' with the number '8' inside it when playing on the viewfinder, which leads me to believe the oldest tapes were created with an analog camera, so the resulting default capture is a single avi file for the entire tape. Does that sound correct (even in Premiere)? -
hi8 and d8 use the same tape but hi8 is analog and d8 is digital. it's been too long for me to recall if analog 8s had time codes recorded.
Same here, turns out it was 2011 when I started this project. Trying to get my head back into it ...
Use SCLive, a better tool.
Your tape is a D8 tape and it will have timecodes on it ie it's DV on the big cassette. See my website here: https://www.aaproductions.net/vid8.htmOriginally Posted by Krypto
WinDV is the simplest to use, although Scenalyzer has more features (mainly for editing) and on some systems works when WinDV won't.
I have speils on both here;
https://www.aaproductions.net/windv.htm
https://www.aaproductions.net/scenalyzer.htm
Enjoy! -
+1. I was about to make the same suggestion.
SCLive makes it really easy and obvious as to how your captures will be segmented. You can choose to have a new file created when the file size gets to a certain point (which used to be helpful, but probably is not any more). You can do optical scene detection and segment files when the camera starts and stops, but this is not 100% reliable and I would recommend doing scene detection using AVISynth and then importing the scene markers from that operation.
if you end up capturing Digital8 tapes, you can have the capture start and stop every time the camera started and stopped. However, as was already pointed out, Hi8 is an analog format, so there is no digital timecode for the capture software to use for scene detection.
Missing pixels with s-video vs. firewire capture Sony DCR-TRV460
By theseeker2 in forum Capturing and VCRReplies: 53Last Post: 23rd Feb 2024, 11:58 -
Capturing Digital8 using Sony DCR Firewire/IEEE 1394 port - scrambled image
By Colek in forum Capturing and VCRReplies: 22Last Post: 24th Aug 2021, 01:42 -
Sony DCR-TRV 330E PAL not visible to computer nor video capture software
By Rahneshin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 7th May 2021, 11:30 -
By Rahneshin in forum Newbie / General discussionsReplies: 0Last Post: 6th May 2021, 10:52 -
Capture quality from Sony DCR-PC100E ?.
By iosman in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2021, 15:50
