As the title says, multiple instances are allowed from the configuration, yet I can't run it. I downloaded the portable version from VideoHelp. Any workarounds?
[Attachment 86093 - Click to enlarge]
[Attachment 86094 - Click to enlarge]
Update: I decided to try a different source, this time, downloaded from portabbleappsplatform.com. This one worked. The one hosted here seems to be from a different website. Anyway. problem solved.
I often create my own portable app by installing a program, copying the files to another location, uninstalling the program, then moving the files back to where they were or putting them on my NAS.
How to control multiple instances using vlc console?
By Belini in forum Software PlayingReplies: 0Last Post: 8th Mar 2022, 14:26 -
Poll : How many instances of ffmpeg on your system, for what total size ?
By abolibibelot in forum ComputerReplies: 5Last Post: 17th Oct 2021, 19:37 -
Potplayer- How do you save multiple playlists all at once?
By tra in forum Software PlayingReplies: 4Last Post: 15th Mar 2021, 16:58 -
potplayer multiple instances, how to play 2 videos at same time?
By wtfiwinomgs in forum Newbie / General discussionsReplies: 10Last Post: 30th Jun 2020, 19:49 -
PotPlayer/VLC, display multiple cover art images.
By Art Poulos in forum AudioReplies: 1Last Post: 12th May 2020, 17:17
