Hello. I have the following problem when trying to deinterlace an AVI file that I have digitized from a MiniDv camera using the WinDv program.
Script Error
MVTools: no BLITCHROMA function for block size 4x16
(C:\Users\cohp\Downloads\StaxRip-v2.44.4-x64\Apps\Plugins\AVS\QTGMC\QTGMC.avsi, line 645)
(C:\Users\cohp\Videos\Video 1.avi_temp\Video 1.avs, line 26)
[Attachment 86027 - Click to enlarge]
Hello, i'm having a similar issue and what I could find was this:
Q: I am getting the error message "MV tools: no BlitChroma function for block size 4x16".
A: You are trying to process interlaced footage without activating of the deinterlacing first (toggle it on in the 'avs\pre-proc.txt')
By default deinterlacing is 'ON' only for DV sources (which are YUV 4:1:1, SD resolution)
If it makes sense to you or you fixed doing something different please let me know
How do I fix this error? I got MVTools installed tho (AviSynth+)
By yoeymeme in forum RestorationReplies: 2Last Post: 11th May 2024, 02:08 -
StaxRip .dll error
By johnkins in forum Video ConversionReplies: 1Last Post: 14th Apr 2024, 23:03 -
File size 3x bigger when using Avisynth trim function through VDub2
By VideoYak in forum Newbie / General discussionsReplies: 6Last Post: 9th Sep 2023, 06:58 -
AviSynth Script error: there is no function named "setmtmode"
By minimax in forum RestorationReplies: 27Last Post: 10th Sep 2021, 03:57 -
I wrote a function, but I have an error that I can't solve.
By Kuronoe in forum Newbie / General discussionsReplies: 3Last Post: 22nd Feb 2021, 10:38
