  1. The only drivers I can locate for a Radeon Vega onboard motherboard GPU are in the Adrenaline series. My motherboard for this is an ASUS A320. The setup disk specifies it only runs on Win 10 and I've successfully used it for Win 10 setup. I want to continue to use Win 7. Radeon drivers must go way back. The Adrenaline series goes back to 2019. Anything before that in Vega that videohelp can find?
  2. @doman
    Thanks for answering
    Down in the comments of that Russian page are posts like:
    "I’m trying to make 3400g APU working on Windows 7 x64 OS. Tried this modded display driver but it returns “Windows has stopped this device because it has reported problems. (Code 43)” error. What am I doing wrong?
    Already tried clean installation with DDU."
    I think these are experimenters and ok for that but would avoid such a source since I don't know enough about fixing possible lockups etc.
    Ideally the Vega driver would be on somebody's install disk from the company. I may just have to move on from trying to put this square peg in the round hole.
    And since the monitor plays everything when getting signal, it may be in the hardware which is a very old HP 1740 LCD.
