Posting in the newbie section because I've never really used anything other than handbrake.
I know enough to tell it's telecined, but handbrake's detelecine feature doesn't seem to be enough or maybe there's some other issues I don't know enough to recognize. No matter what I do, there seems to be a lot of ghosting. Especially with the writing on the bus and the old man's legs when he gets thrown off the bus.
Would greatly appreciate it if someone with proper experience could take a look at the attached clip and tell me what I'm working with here, hopefully point me in the right direction.
Results 1 to 23 of 23
BrianCrowe,
just so you know, it appears to have been converted from 24fps to 30fps using field blending.
It'd require a crash course in using Avisynth Plus to remove the blending (or hopefully most of it).
QTGMC and SRestore (mentioned by davexnet in the post above) are Avisynth functions.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Keep in mind that SRestore needs to access frames in a linear manner to find the blending pattern. If you navigate back and forth in the video while viewing the output of the script you'll probably see blends. You need to either play the video or step through the frames in playback order. SRestore can still miss a few initial blends, or miss a few blends if the blending pattern changes, as sometimes it does.
Dave must be using the secret sauce because I too cannot achieve his result. In the bit where the bloke is falling backwards, I'm still getting blends and interlacing.
Here's mine using Dave's code.
Edit: Mine came out at 29.97, but SRestore was told 23.976. Naughty SRestore??Last edited by Alwyn; 10th Mar 2025 at 19:52.
Dave, code exactly the same as yours (as stated).
I'm on SRestore 2.797 and same masktools.
What bitness are you using? -
I used the 32 bit version 44282 from 2020
https://www.videohelp.com/download/VirtualDub2_44282.zip
I don't know if grunt.dll could be an issue, the doc for Srestore says it could be used in some cases.
I just noticed I've a really old version from 2008 in my 32 bit plugins folder.
Perhaps related to the source filter? I'm using LsmashSource.dll version 1167Last edited by davexnet; 11th Mar 2025 at 00:15.
I'm on 64 bit. Lsmash did improve things a bit, but I still have ghosting/blends.
We had a thread recently (in the last couple of months, IIRC) with a similar video and a good solution but I'll be danged if I can find it. -
I don't know if this was the correct thing to do or not, but after a lot of testing I was able to get a satisfactory result by enabling qtgmc's bob function.
The problem I'm facing now is finding some way to reduce the amount of jiggling/warping it causes or reveals in slow panning shots like in the attached clip. Does anyone know of a different filter or tweaks to srestore that can alleviate that?
In the attached files is the second clip I'm having an issue with, and the best version I've been able to make of the first clip.
And I must say thank you to everyone that has responded to this thread. I honestly didn't expect this much of a response or this much help -
The wobbling is in the source. You can examine it with SeparateFields() and step through the individual fields
Code:LWLibavVideoSource("GTO test2-001.mkv") SeparateFields()
https://www.animemusicvideos.org/guides/avtech31/video-analyze.html
In general, you cannot fix this without extensive manual work . You might be able to select specific frames, or interpolate over some bad frames, or recreate the pan from a larger plate, but all thes require some manual input, at minimum identifying and specifying "good" frames. It won't be a simple script that you can generically apply to everythingLast edited by poisondeathray; 11th Mar 2025 at 17:05.
Actually for your test scene, if you change the deinterlacer to bwdif(field=3) or yadif(1,1), srestore picks the correct frames . The negatives of those are more aliasing in general . One of the side effects of QTGMC is slight wobbling, and it must be enough in this case to confuse srestore
This doesn't mean that workaround will work for all scenes. It depends on how the transfer was done, where it was edited, the cadence -
Originally Posted by BrianOriginally Posted by Brian
Here's what I used for that clip:
Code:Crop(6,0,-6,0) AssumeTFF() QTGMC(Preset="Placebo", ediThreads=2) srestore(frate=23.976,omode=6,speed=1,thresh=20,cache=5)
I'll encode the entire episode with bwdif instead of qtgmc and see how it turns out, thank you! I'm not really going for perfect, just more enjoyable to watch than the source.
Just for reference however, how long do you think it'd take someone with proper experience to manually fix up something like this? -
You could probably fix some of the wobble with Stab.
You can ignore the warning on the wiki about not using it with color video.
http://www.avisynth.nl/index.php/Stab
I'm not sure if it'll work better before or after the de-interlacing. You'll have to experiment with that.
Stab()
CheckMate()
SRestore(frate=24000.0/1001.0, omode=6, speed=1, thresh=20)
CropResize(0,476, 12,2,-10,-2, InDAR=15.0/11.0, Resizer="Resize8")
FineDehalo()
MergeChroma(last, aWarpSharp2(depth=20))
FastLineDarkenMod4(thinning=0)
MAA()
FineDehalo()Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Progressive video source with a few interlaced/telecined frames
By GlitchBob in forum EditingReplies: 3Last Post: 17th Aug 2023, 04:14 -
Low quality videos encoded in H.265 (NVEnc) even with High Quality and CQ=1
By bookagood in forum Newbie / General discussionsReplies: 13Last Post: 18th Aug 2021, 11:18 -
Difficult Decimation Source
By ZacharyGeorgeNN in forum DVD RippingReplies: 5Last Post: 8th May 2021, 16:46 -
Nvidia HEVC very low quality?
By Jiehfeng in forum Video ConversionReplies: 16Last Post: 25th Nov 2020, 11:23 -
low quality movie
By gargamel9 in forum RestorationReplies: 2Last Post: 13th Jun 2020, 08:32
