My use of SE was interrupted today when seeing the video player MVP in the program was jerking and dropping a lot of frames. I tried a reinstall but no improvement. While I am on a new motherboard the rest of my playback or streams etc are normal. Would using the player alterantive install
improve this?
Also, might changing the resolution reduce some graininess in the image? These are two separate issues.
I'll put in a MediaInfo for anyone to see:
General
Unique ID : 265712405115659209659968289703904073370 (0xC7E65906D90D3ABAFA999F6692EAD69A)
Complete name : C:\Users\lon\Desktop\Gabriel (2013) Samuel Adamson - [1080p]\Samuel Adamson - Gabriel (Shakespeare's Globe Theatre) [1080P] (2013) recodes -1.mkv
Format : Matroska
Format version : Version 4
File size : 1.39 GiB
Duration : 2 h 28 min
Overall bit rate : 1 347 kb/s
Frame rate : 25.000 FPS
Encoded date : 2025-03-02 02:08:30 UTC
Writing application : HandBrake 1.3.3 2020061300
Writing library : Lavf58.29.100
ErrorDetectionType : Per level 1
Video
Format : AVC
Format profile : Main@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Width : 1 020 pixels
Height : 540 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 157 r2935 545de2f
Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Title : Stereo
Language : English
Default : Yes
Forced : No
No obvious problems in your file.
PC problem?
Run dxdiag from the command line and look for errors in each of the tabs, especially the "system" and "display" tabs -
I'll see what dxdiag is.
For a comparison I'm going to load that job on a Win10 install that shows a driver for the onboard graphics rather than the generic PnP install on this Win7.
The board i'm using is something that fell in the cracks of compatibility problems. In Other words, the set up disk is for Win10 and above. -
I did not see dxdiag in the videohelp software group.
But I have loaded the video into the current updated Subtitle Edit with Win10 on an SSD and it looks much better: no jaggies or frame skips.
On the dxdiag , the most I can do is go to c:\ type it in and hope it runs. I encoundter too much trouble with
command line. -
Videohelp software?
It's a Windows diagnostic program, included with Windows, run it from a command prompt or RUN box -
All the screens in DXdiag show no problems.
However SE on this motherboard and Win7 go skipping through video. Also of note the boxes for text editing are blank.
I'll have to recreate a Subtitle Edit error involving some path to a DLL and make a screen shot of that. All this has my head spinning.
[EDIT] This SE dll error could be because not on Windows 10.
Anyway news of the day is dxdiag found no errors. One thing at a time.Last edited by loninappleton; 10th Mar 2025 at 16:26.
Reinstalling video player in Subtitle Edit
By loninappleton in forum SubtitleReplies: 10Last Post: 30th Dec 2023, 00:28 -
Subtitle edit - How to put 'A with a dash on top' in subtitle edit?
By SSEN in forum SubtitleReplies: 5Last Post: 21st Sep 2023, 21:57 -
Subtitle Edit : Capitalize Subtitle to Normal Subtitle incomplete
By kalemvar1 in forum SubtitleReplies: 6Last Post: 5th Aug 2023, 13:28 -
Premiere > EDL > Subtitle Edit > SRT > most timings are 1—2 frames early
By dimailer in forum SubtitleReplies: 1Last Post: 5th May 2023, 00:56 -
FFMPEG dropping frames
By Compositor in forum Video ConversionReplies: 6Last Post: 12th Dec 2022, 13:29
