  1. What program can transfer VTT subs to SRT just as text? I saw in Subtitle Edit that the Save as SRT option retained all the VTT coding.
    This simply helps anyone who does corrections to look through less extra info on the sub.
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    In subtitle edit, you can select all dialogue lines, right click > Remove formatting > Remove all formatting
  3. Thanks for reply. I will do that.
  4. You have many webs to do that. You dont need any software nowadays.
    canada
    I wouldn't trust any website for online editing of anything,i use subtitle edit for all my subs.
  6. Originally Posted by loninappleton View Post
    You can use clever FFmpeg-GUI.
    Load your vtt (or a movie with a vtt subtitle track), click main page, click convert subtitle stream.
    Select you subtitle stream (if more then one), set convert to subrip or text, click convert.
    Done.
  7. Originally Posted by johns0 View Post
    Agreed. It's just another data collection point.
