I am attempting to play an HLS encrypted stream for which I subscribe using Kodi. The URL of the manifest (after I redacted all of the sensitive token information) is:
This is what the inside of the manifest looks like:Code:https://primarystream.365cdn.net/laligatv/laligatv.m3u8?Policy=<redacted>Key-Pair-Id=<redacted>Key-Pair-Id2=<redacted>&DVR=1&DVR=1
Inside la-ligatv-1080.m3u8:Code:#EXTM3U #EXT-X-VERSION:3 #EXT-X-INDEPENDENT-SEGMENTS #EXT-X-STREAM-INF:BANDWIDTH=5530800,AVERAGE-BANDWIDTH=5530800,CODECS="avc1.64002a,mp4a.40.2",RESOLUTION=1920x1080,FRAME-RATE=50.000 https://server-4.365cdn.net/laligatv/laligatv-1080.m3u8?Policy=<redacted>Key-Pair-Id=<redacted>Key-Pair-Id2=<redacted>&DVR=1&DVR=1
Within my .strm file I have:Code:#EXTM3U #EXT-X-VERSION:3 #EXT-X-TARGETDURATION:8 #EXT-X-MEDIA-SEQUENCE:170131 #EXT-X-KEY:METHOD=AES-128,URI="K66170100-1080.key?u=<redacted>&Key-Pair-Id=<redacted>&u=<redacted>&DVR=1&DVR=1",IV=0x<redacted> #EXT-X-PROGRAM-DATE-TIME:2025-03-07T10:32:35.720Z #EXTINF:4.00000, laligatv-108020250307T103236_170131.ts #EXTINF:4.00000, laligatv-108020250307T103240_170132.ts #EXTINF:4.00000, laligatv-108020250307T103244_170133.ts #EXTINF:4.00000, laligatv-108020250307T103248_170134.ts #EXTINF:4.00000, laligatv-108020250307T103252_170135.ts #EXTINF:4.00000, laligatv-108020250307T103256_170136.ts and so on
I receive the following errors in the Kodi log:Code:#EXTINF:-1,Test1 #KODIPROP:inputstream=inputstream.adaptive #KODIPROP:inputstream.adaptive.manifest_type=hls #KODIPROP:inputstream.adaptive.stream_headers=User-Agent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:135.0) Gecko/20100101 Firefox/135.0&Accept: /&Accept-Language: en-GB,en;q=0.5&Accept-Encoding: gzip, deflate, br, zstd&Origin: https://www.premiersports.com&connection/: keep-alive&Referer: https://www.premiersports.com/&Sec-Fetch-Dest: empty&Sec-Fetch-Mode: cors&Sec-Fetch-Site: cross-site&TE: trailers https://primarystream.365cdn.net/laligatv/laligatv.m3u8?Policy=<redacted>Key-Pair-Id=<redacted>Key-Pair-Id2=<redacted>&DVR=1&DVR=1
When I play the file in MPV it works fine but not in Kodi. Likewise it also does not work in VLC which leads me to believe it's a problem with the headers. I attempted to copy the headers from Firefox when I am on the website. When I remove the headers from the .strm file, I receive the same error.Code:2025-03-07 14:22:36.132 T:1004 error <general>: CCurlFile::Stat - <https://primarystream.365cdn.net/laligatv/laligatv.m3u8?Policy=<redacted>Key-Pair-Id=<redacted>Key-Pair-Id2=<redacted>&DVR=1&DVR=1> Failed: HTTP response code said error(22) 2025-03-07 14:22:36.143 T:1004 info <general>: VideoPlayer::OpenFile: /storage/tv2.strm 2025-03-07 14:22:36.232 T:4347 error <general>: CCurlFile::Stat - <https://primarystream.365cdn.net/laligatv/laligatv.m3u8?Policy=<redacted>Key-Pair-Id=<redacted>Key-Pair-Id2=<redacted>&DVR=1&DVR=1> Failed: HTTP response code said error(22) 2025-03-07 14:22:36.232 T:4347 info <general>: Creating InputStream 2025-03-07 14:22:36.235 T:4347 info <general>: AddOnLog: inputstream.adaptive: [Repr. chooser] Resolution set: 1920x1080, max allowed: 1920x1080, Adjust refresh rate: 0 2025-03-07 14:22:36.556 T:4347 error <general>: AddOnLog: inputstream.adaptive: Download failed, HTTP error 422: https://primarystream.365cdn.net/laligatv/laligatv.m3u8?Policy=<redacted>Key-Pair-Id=<redacted>Key-Pair-Id2=<redacted>&DVR=1&DVR=1 2025-03-07 14:22:36.556 T:4347 error <general>: CVideoPlayer::OpenInputStream - error opening [/storage/tv2.strm] 2025-03-07 14:22:36.556 T:4347 info <general>: CVideoPlayer::OnExit() 2025-03-07 14:22:36.556 T:4347 info <general>: ADDON: Dll Destroyed - InputStream Adaptive 2025-03-07 14:22:36.581 T:1004 info <general>: CVideoPlayer::CloseFile() 2025-03-07 14:22:36.581 T:1004 info <general>: VideoPlayer: waiting for threads to exit 2025-03-07 14:22:36.581 T:1004 info <general>: VideoPlayer: finished waiting
Could you please assist? Thank you.
Results 1 to 1 of 1
Record from Kodi with Pilfer
By NapoleonWils0n in forum User guidesReplies: 3Last Post: 5th Mar 2025, 06:07 -
Problem With HLG not recognised on FireTv Stick 4K KODI
By mx25 in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2025, 13:25 -
Firestick VLC and Kodi can't find media on PC server
By dac10012 in forum Media Center PC / MediaCentersReplies: 5Last Post: 8th Oct 2023, 01:28 -
How to change audio offset step by 1 instead of 25 on Kodi?
By Runakanta in forum Newbie / General discussionsReplies: 7Last Post: 30th Dec 2022, 09:18 -
Change This Kodi Code to Other IPTV App Source
By zubzub in forum Newbie / General discussionsReplies: 0Last Post: 16th Dec 2022, 07:45
