    Jan 2008
    I've been using this off and on for quite a while. It quit working so I had to buy again. Immediately I had problems and got what I would say was some of the worst tech support service I've seen. Normally there are just a few music streams that I like to be able to play back later. It used to be I'd set it to "auto" and then start the stream and it would pick it up. For the last year, anytime I put it on auto, it would turn on proxy on my Windows PC. This would block any of my browsers from working and nothing would happen in RMC. I thought after I just paid for the upgrade that I would get some help with this but I just get a form reply. Eventually, although I'm not educated in the inner workings of web pages, I could figure out some streams actual urls and would manually paste them into RMC. Also, I couldn't do this with any videos on Facebook (which I used to be able to do). Pasting the URL just brought an error. I tried putting it on "auto" but then was back in the cycle of RMC starting a proxy and cutting off all web. I also used to download some longer videos from Youtube. Lately, if it's any length at all, it downloads at a super slow rate until it eventually times out. It also doesn't show any progress report like it used to. Does anyone here have experience with this program and any idea if it can be fixed or at least another program that can download Youtube (and maybe Facebook) videos? Thanks!
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You can use yt-dlp for downloading youtube videos
    Jan 2008
    I see I have that already on my PC. I use Smplayer and can view Youtube videos through that. How do I do the downloading through yt-dlp? Thanks.
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Well if you want to download
    https://www.youtube.com/watch?v=jNQXAC9IVRw
    You download yt-dlp and put it in a random folder of your choice. You open cmd in that folder by typing cmd in the path address file bar and pressing enter. And then you copy paste the download command and press enter
    yt-dlp "https://www.youtube.com/watch?v=jNQXAC9IVRw"
    It will download the file in the same folder.
    [Attachment 85972 - Click to enlarge]
    Jan 2008
    OK. I'll try that out. Thanks!
    Jan 2008
    I got it to download a youtube video. Way faster! Thanks!! Any suggestion on downloading FB videos. Replay Media Capture used to be able to do it last year but no longer. Thanks
  7. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Same thing. Just use the page url. For example you can download
    https://www.facebook.com/Naturelove.Mik/videos/the-nature-is-absolutely-amazing-look-a...7181183313798/
    using
    yt-dlp "https://www.facebook.com/Naturelove.Mik/videos/the-nature-is-absolutely-amazing-look-at-this-water-danceing-%EF%B8%8Fwaterfall-fb-reels/1017181183313798/"
    Jan 2008
    Excellent! I'll be trying that out next. Thanks!!
