  1. Hi all. I need anyone write regex to working on livestreams pro for this site:
    https://player.mediaklikk.hu/playernew/player.php?video=mtv1live
    Please help me and thank.
    Oct 2022
    Behind You
    The livestream on this site isnt protected at all, no regex is needed, just go to network tab and look for the m3u8
    I help all that ask.
  3. ffmpeg -i "https://c402-node62-cdn.connectmedia.hu/110301/420d053aab581bf00ef5c3d89592d92e/67c72527/index.m3u8" -c copy v.ts
  4. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    Try this:
    #EXTM3U
    #EXT-X-VERSION:5
    #EXT-X-MEDIA:TYPE=AUDIO,URI="https://c401-node62-cdn.connectmedia.hu/110301/32f1cd5ab416830945b9f503e5680a6a/67cafacb/301-M1_NOGEO-mp4a_140800_hun=1.m3u8",GROUP-ID="audio-AACL-141",LANGUAGE="hu",NAME="magyar",DEFAULT=YES,AUTOSELECT=YES,CHANNELS="2"
    #EXT-X-STREAM-INF:BANDWIDTH=4470590,AVERAGE-BANDWIDTH=4064173,CODECS="avc1.640028,mp4a.40.2",RESOLUTION=1920x1080,FRAME-RATE=25.000,AUDIO="audio-AACL-141"
    https://c401-node62-cdn.connectmedia.hu/110301/32f1cd5ab416830945b9f503e5680a6a/67cafacb/301-M1_NOGEO-avc1_3699968=7.m3u8
  5. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Here's an alternative solution if by regex you mean this
    import re
    import requests
    SOURCE_URL = "https://player.mediaklikk.hu/playernew/player.php?video=mtv1live"
    if __name__ == '__main__':
        response = requests.get(SOURCE_URL).text
        response = re.findall(
            r'"file"[^:]*:[^"]*"([^"]+)"',
            re.findall(
                r'"playlist"[^:]*:[^\[\]]*\[([^\[\]]*)]',
                response,
                re.MULTILINE
            )[0],
            re.MULTILINE
        for playlist in response:
            playlist = playlist.replace(r"\/", "/")
            command = f'streamlink "{playlist}" best'
            print(command)
    Output:
    streamlink "https://c402-node62-cdn.connectmedia.hu/110301/149565f24e7c1ea453de4bc3530ed4e1/67c747a0/index.m3u8?v=5iip:<snipped>" best
  6. Thank all for help...But any code not working on livestreams pro on kodi.
    this is the regex of the M1 channel but now it doesn't work on kodi anymore. I want to fix it and thanks everyone
    <item>
    <title>M1</title>
    <link>httpdoregex[Url]|User-Agent=iPad</link>
    <regex>
    <name>m3u8</name>
    <expres>file": "(.*?)"</expres>
    <page>https://player.mediaklikk.hu/playernew/player.php?video=mtv1live</page>
    <referer>https://player.mediaklikk.hu/</referer>
    </regex>
    <regex>
    <name>Url</name>
    <expres>$pyFunction:'$doregex[m3u8]'.replace('\/','/')</expres>
    <page></page>
    </regex>
    </item>
  7. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    Or without regex (windows) ... "s t r e a m 1080p hungary M 1 TV.cmd " :
    @echo off
    set "audio=https://c201-node62-cdn.connectmedia.hu/110301/cec9cadc015408be5c022a9ee473b1e3/67c72763/301-M1_NOGEO-mp4a_140800_hun=1.m3u8"
    set "video=https://c201-node62-cdn.connectmedia.hu/110301/cec9cadc015408be5c022a9ee473b1e3/67c72763/301-M1_NOGEO-avc1_3699968=7.m3u8"
    set "channel=s t r e a m 1080p hungary M 1 TV"
    set "vlc=%SystemDrive%\\progra~1\\VideoLAN\\VLC\\vlc.exe"
    for /f %%a in ('powershell -Command "Get-Date -format yyyy.MM.dd#HH.mm.ss"') do set datetime=%%a
    start "" /SEPARATE ffmpeg -i "%audio%" -i "%video%" -c copy "%channel%_%datetime%.ts"> nul
    timeout /t 3 /nobreak> nul
    if exist "%channel%_%datetime%.ts" start "" %vlc% --meta-title=" %channel%  %datetime% " --file-caching=200 --fullscreen --directx-volume=1.0 --quiet "%channel%_%datetime%.ts"
    exit
  8. Member G.T.X.R's Avatar
    Jan 2025
    Europe
    I don't know KODI well. But this is the last attempt for me to get m 1 working on windows 7... Create "_s t r e a m 1080p hungary M 1 TV_.cmd"
    @echo off&& cd /D "%~dp0"&& chcp 1252&& cls
      title=  - r e c  o r  p l a y  m 1  - G.T.X.R. Vers: 0.0.3
    rem SWITCH: {toggle} start vlc (play) or start ffmpeg (rec)
    rem set "start=vlc"
        set "start=ffmpeg"
    SETLOCAL ENABLEEXTENSIONS ENABLEDELAYEDEXPANSION
    set "url=https://player.mediaklikk.hu/playernew/player.php?video=mtv1live"
    set "REF=https://player.mediaklikk.hu/"
    set "Agent=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.0 Safari/605.1.15"
    rem ::HU= 084.000.000.000  084.003.255.255::
    rem :: : :::::::r a n d o m  i p::::::: : ::
    set maxval1=84
    set minval1=84
    set maxval2=3
    set minval2=0
    set maxval3=255
    set minval3=0
    set maxval4=255
    set minval4=0
     SET /A N0=%RANDOM% * 255 / 32768
     SET /A N1=%RANDOM% * ^(%maxval1% - %minval1% + 1^) / 32768 + %minval1%
     SET /A N2=%RANDOM% * ^(%maxval2% - %minval2% + 1^) / 32768 + %minval2%
     SET /A N3=%RANDOM% * ^(%maxval3% - %minval3% + 1^) / 32768 + %minval3%
     SET /A N4=%RANDOM% * ^(%maxval4% - %minval4% + 1^) / 32768 + %minval4%
    SET  "IP=%N1%.%N2%.%N3%.%N4%"
    ECHO.generated ip= %IP%
    if exist ".\*.log" del /F /Q ".\*.log"
    if exist ".\%channel%.m3u8" del /F /Q ".\%channel%.m3u8"
    wget -c --no-check-certificate -U "%Agent%" --referer=%REF% --header="X-Forwarded-For:%IP%" %url% -q -O "a.log"
    sed "s'\\/'/'gi; s/,/,\n/gi; " "a.log" > "b.log"
    sed "/\x22file\x22:/^!d; " "b.log" > "c.log"
    sed "s/.*\(https:\/\/.*\)\x22,.*/\1/gi; " "c.log" > "d.log"
    for /f "usebackq tokens=* delims=*" %%M in ("d.log") do ( set "M3U8=%%M" )
    sed "s/.*\(https:\/\/.*\.connectmedia\.hu\/.*\/.*\/.*\)\/index\.m3u8.*/\1/; " "c.log" > "e.log"
    for /f "usebackq tokens=* delims=*" %%I in ("e.log") do ( set "init=%%I" )
    wget -c --no-check-certificate -U "%Agent%" --referer=%REF% --header="X-Forwarded-For:%IP%" %M3U8% -q -O "f.log"
    sed " s/\\n/\n/gi; " "f.log" > "g.log"
    sed "/426x240/d; /640x360/d; /854x480/d; /960x540/d; /1280x720/d; /301-M1_NOGEO-avc1_400000/d; /301-M1_NOGEO-avc1_699968/d; /301-M1_NOGEO-avc1_1099968/d; /301-M1_NOGEO-avc1_1499968/d; /301-M1_NOGEO-avc1_1800000/d; " "g.log" > "h.log"
    for /f "usebackq tokens=* delims=*" %%G in ("h.log") do (
    set "STREAM=%%G"
    set "STREAM=!STREAM:301-M1_NOGEO-mp4a=%init%/301-M1_NOGEO-mp4a!"
    set "STREAM=!STREAM:301-M1_NOGEO-avc1=%init%/301-M1_NOGEO-avc1!"
    echo.!STREAM!>> "i.log"
    echo.!STREAM!>> "%channel%.m3u8"
    sed "/301-M1_NOGEO-mp4a_140800_hun=/^!d; " "i.log" > "j.log"
    sed "/301-M1_NOGEO-avc1_3699968=/^!d; " "i.log" > "x-video.log"
    sed "s/#EXT-X-MEDIA:TYPE=AUDIO,URI=\x22\(https.*\.m3u8\)\x22,GROUP-ID=.*/\1/; " "j.log" > "x-audio.log"
    for /f "usebackq tokens=* delims=*" %%A in ("x-audio.log") do ( set "audio=%%A" )
    for /f "usebackq tokens=* delims=*" %%V in ("x-video.log") do ( set "video=%%V" )
    IF "%start%"=="vlc" (
    if exist ".\%channel%.m3u8" start "" %vlc% --file-caching=200 --fullscreen --directx-volume=1.0 --quiet ".\%channel%.m3u8"
    IF "%start%"=="ffmpeg" (
    exit
