Results 1 to 9 of 9
  1. hey, can anyone help me the steps to get hd video from viki
    video link- https://www.viki.com/videos/1233367v
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
  3. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    thank you, For Hd we need pass as you said, Nm3u8dl finds the PSSH and kid automatically, though how can i find it manually ? can you please tell
  4. what am i suppose to do with the ready to use widevine devices ? how to make it work sfter installing the zip file
  5. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You get a wvd file, you import it in the addon and you use it. Have you read the tool post at least?
  6. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    i did, so to create the wvd file i just need to do this commad
    pywidevine create-device -k device_private_key -c device_client_id_blob -t "ANDROID" -l 3 ( replacing device_private_key and client_id_blob as client_id.bin & private_key.pem as these are the files in that folder ) need to install pywidevine first through pip right ? is this process correct ?
  7. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
  8. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    thank you so much. It worked, i used already converted one, because the one i am converting is not showing any output as wvd
