Hi, does anyone know how I can crop the black left and right borders on a 16:9 video to 4:3 in Adobe Premiere?. I have looked up a few videos tutorials on youtube but couldn't find anything that crops them. Going into project settings and changing the size 1140x1080 results in part of the sides being cropped off where it shouldn't be. I couldn't find anything that allows you to adjust the sides by inputting in 240 for left and 240 for right like you can do with Handbrake and Avidemux.
It should be 1440 x 1080 , not 1140 x 1080
Was your video 4:3 content with pillar bars as 1920 x 1080 with "square pixels" ?
Or was it SD dimensions with "non square pixels ?" - Because PP's default interpretation of aspect ratio for SD content is slightly different and there are other steps to take -
Movies come in many different aspect ratios. Not just 4:3 and 16:9.
https://en.wikipedia.org/wiki/List_of_motion_picture_film_formats
Are you sure your source is 4:3? -
One might disagree but if you start with a 4:3, or similar, video with burnt in side-bars and then crop away those bars you will then
1. Potentially lose quality with the re-encode
2. Your player then re-adds those side-bars when you play the video on a 16:9 full-screen
Thus a waste of time.
Video Doesn’t Load Into Premiere Pro When Importing Clip. Only Audio Does
By jealousy91 in forum EditingReplies: 4Last Post: 25th Feb 2022, 12:35 -
Adobe Premiere Pro 2022 Video in Timeline?
By vega69-ux in forum EditingReplies: 0Last Post: 24th Feb 2022, 19:30 -
Bink Video plugin for Premiere Pro
By PU User in forum EditingReplies: 6Last Post: 7th Jul 2021, 04:58 -
Is Final Cut Pro really that much better than Adobe Premiere Pro?
By videoguy102 in forum EditingReplies: 5Last Post: 9th Oct 2020, 06:34 -
Premiere Pro CS6 crashing - is Nvidia video card to blame ?
By Bansaw in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2020, 16:04
