I received a DVD transfer (and a very crappy one at that) of a live concert and, apart from the very clear low resolution and cropped overscan, there is some serious flagging jitter. Recapturing with a better setup is not possible (even though i got a VHS transfer setup that yields higher quality than this) as this DVD transfer was made by some unknown person whom i cannot contact and don't even know if they still have the tape.
I was wondering if this was possible to fix with AviSynth and some plugin.
Attached here is a 30 second sample (yes, i know the audio is out of sync, but that can be fixed.):
sample.vob (cut with ffmpeg using -c copy so it doesn't reencode)
Last edited by Fedex; 2nd Mar 2025 at 04:55. Reason: corrected "flagging" to jitter
That video is so poor I don't think you'll get much improvement.
Plenty of stabilizer tools; look into Mercalli -
Hopeless crap. It has all defects one can imagine.
You could try with DeJitter, but in order to make it work you should have some black side borders in your video as a reference.
http://www.avisynth.nl/users/vcmohan/DeJitter/DeJitter.htm -
Couldn't manage to do anything useful with dejitter, the video is screwed up beyond repair i believe.
Help restoring poor quality source tape
By Traderbam in forum RestorationReplies: 16Last Post: 21st Feb 2025, 03:08 -
JVC HR-S7600AM S-VHS VS. HM-DH5U D-VHS Capturing a VHS Tape
By dellsam34 in forum Capturing and VCRReplies: 26Last Post: 25th Aug 2023, 10:18 -
How do i fix flagging(tearing) in this video?
By gil900 in forum RestorationReplies: 22Last Post: 7th May 2023, 11:03 -
Captured VHS Tape To AVI Lossless UT Video Now what?
By ngnaw in forum RestorationReplies: 47Last Post: 1st Dec 2022, 16:46 -
VHS Tape is Wrinkled is there a way to fix?
By battybarney in forum Capturing and VCRReplies: 5Last Post: 7th Dec 2020, 04:38
