I re-enconded some videos which have a constant framerate (according to mediainfo) with handbrake and I guess I forgot to select constant framerate instead of variable. I did choose "same as source" for FPS though.
My question is does it matter? I checked the output files and there's no A/V sync issues, at-least on a PC, so can I ignore it or could issues pop up on another device?
same as source/variable should be fine, it would give same frame timing as the source
How can I best change from VFR to CFR and save to Lagarith
By Tom4 in forum Video ConversionReplies: 21Last Post: 13th Jan 2024, 17:04 -
H264: VFR to CFR without re-encoding - possible?
By rgr in forum Video ConversionReplies: 7Last Post: 11th Nov 2023, 11:32 -
How can i convert vfr to cfr with ShutterEncoder? (or handbrake?)
By Lemenus in forum Video ConversionReplies: 8Last Post: 22nd Oct 2023, 08:20 -
VFR vs CFR
By rblu in forum Newbie / General discussionsReplies: 2Last Post: 16th Feb 2021, 14:29 -
VFR to CFR conversion before editing
By droner in forum EditingReplies: 42Last Post: 15th Feb 2021, 04:01
