  1. Hi,
    I am taking several mp4 clips and trying to merge them into one mp4 using Losslesscut. However, a handful of the files have slightly different metadata and won't merge together. Is there a way to match the metadata between files?
    Below is a copy from Losslesscut of the mismatches. I'm unsure if this occurs because the files are comprised of 2 two tracks (audio/video) and they are reversed between the two files? Any help would be greatly appreciated.
    Mismatches detected
    Track 1 mismatch: codec_name aac != h264
    Track 1 mismatch: width none != 1920
    Track 1 mismatch: height none != 1080
    Track 1 mismatch: pix_fmt none != yuv420p
    Track 1 mismatch: level none != 40
    Track 1 mismatch: profile LC != High
    Track 1 mismatch: sample_fmt fltp != none
    Track 1 mismatch: r_frame_rate 0/0 != 30/1
    Track 1 mismatch: time_base 1/44100 != 1/90000
    Track 2 mismatch: codec_name h264 != aac
    Track 2 mismatch: width 1920 != none
    Track 2 mismatch: height 1080 != none
    Track 2 mismatch: pix_fmt yuv420p != none
    Track 2 mismatch: level 40 != none
    Track 2 mismatch: profile High != LC
    Track 2 mismatch: sample_fmt none != fltp
    Track 2 mismatch: r_frame_rate 30000/1001 != 0/0
    Track 2 mismatch: time_base 1/90000 != 1/44100
    Thanks in advance
    Mar 2008
    Every time your issue has been posted in the past, the answer proved elusive and the files had to be re-encoded in the end
    to achieve the join.
    If you like, you can post some samples and somebody will take a look
  3. It looks like the stream order in one/more of the mp4 files is different (e.g. video=1, audio=0, instead of video=0, audio=1).
  4. @ awbowden
    you could use LosslessCut to re-order the tracks, or clever FFmpeg-GUI.
  5. Originally Posted by davexnet View Post
    Thanks for the reply. Can handbrake be used to re-encode?
    If I post a couple mismatched clips someone may see if the can merge them?
  6. Originally Posted by videoAI View Post
    @ awbowden
    I'm not sure how to re-order the tracks. I removed the audio track from the clip but the videos still would merge. Similar mismatch warnings occurred.
  7. I'm not very savvy at any of this...
    I used handbrake to batch re-encode my clips. Then merged them in Losslesscut. It did pop up a few errors still but only about framerate being slightly different. The merged video works! Thanks for the assistance folks!
