    Dec 2022
    Brasil
    The VCR was working, but on the second tape tested, it got stuck. Later I was able to take the tape out but now when I turn it on it does this. My friend who is an electronics technician and I are going to try to fix it, I know it will be complicated, but I want advice, tips, anything to help me fix it.
    https://www.youtube.com/shorts/ES2za9FVq7U
    Dec 2022
    Brasil
    Hello everyone, I'm going to try to fix this device myself. I would like to know if anyone knows of a YouTube video of these guys who disassemble and repair these VCRs, maybe I can find someone disassembling this device. Does anyone have any tips from any youTube channel?
    Mar 2008
    See if you can find something similar at the 12voltvids channel on Youtube
    Dec 2022
    Brasil
    He has not.
  5. Seems like the timing is off in the loading basket/elevator which fits with possible forceful removal of an eaten tape. You can see that the front of it is not going in straight. You've just got to hope that a gear somewhere isn't broken. Most likely isn't going to be a complicated repair, but it should be pretty obvious if it is fixable once the basket is off. An electronics tech should be pretty easily able to reset the timing of a VCR mechanism though, unless they don't do anything mechanical during their usual repairs.
