I saw that DAC50 can convert from 576i ( 4:3 ) to 576i ( 16:9 ) ... and I was hoping that on this conversion some sort of line tbc can be involved... ( VHS )
I know that lordsmurf has some experience with datavideo DAC . And maybe he tried this...
lordsmurf! lordsmurf! lordsmurf!
Unless your source tape is incorrectly framed, I wouldn't be stretching a 4:3 video to 16:9. It will look very distorted.
DAC in Datavideo-land means Digital to Analog Converter, in the case of the DAC50, it takes a digital SDI signal and converts an analog format like composite or component which is going in the wrong direction for capturing. For captures, you'd want to take something analog and make it digital. There are plenty of devices that do this, but unless they specifically mention that they contain TBCs, they are unlikely to. A widely known example would be the BlackMagic Analog to SDI converter. It'll make analog into digital (opposite of what the DAC50 does) and even embed audio into the SDI stream, but it won't do any time base correction. It'll work if used with a TBC before it in the chain, but it really won't work for magnetic/mechanical media as the signal is too unstable to make a digitally precise signal in realtime unless it is already very stable going into the unit.
Interesting rebuilt Datavideo TBC-1000 on ebay
By nicholasserra in forum Capturing and VCRReplies: 76Last Post: 8th Nov 2024, 11:00 -
datavideo tbc-5000
By matsta in forum Capturing and VCRReplies: 0Last Post: 29th Dec 2022, 05:23 -
Does the Datavideo SE-200 have TBC?
By Darryl In Canada in forum Capturing and VCRReplies: 1Last Post: 27th May 2021, 14:13 -
Anyone serviced a DataVideo TBC-1000
By dogbait in forum Capturing and VCRReplies: 2Last Post: 26th Jul 2020, 17:33 -
Datavideo TBC-1000 Dark Results
By TONYFRANCE in forum Capturing and VCRReplies: 8Last Post: 11th Jun 2020, 14:46
