Sorry for posting in this section, I didn't find a section dedicated to VCRs. If there is a better section, admin or mod please put it in the right place.
My problem is that I am only getting image from a Panasonic NV-HS900 VCR with cassettes recorded in SVHS via S-Video cable. I am using a Yamaha RX-V2067 AV receiver connected to the VCR via S-Video cable and analog audio (RCA). TV are connected to AV receiver via HDMI cable. AV receiver is able to convert video, is not just passing through. Sound is working, but image only works if I am playing a cassette recorded in SVHS. And only on PLAY mode. If I try to fast play or fast rewind on the heads (JOG and SHUTTLE) or PAUSE, image is also not working. On standard VHS image is only working for a brief period, then screen goes blank. On SVHS is clear and runs smoothly. Anyone has any idea why is this happening and how to fix it? Thanks.
I'm sharing my response that I posted in your Tapeheads thread:
It's either the analog to digital converter inside your receiver not locking to the video due to frame sync issues, S-VHS recordings are usually of a better quality so the timing signals are good, not so much in trickle play and regular VHS, Or it could also be your VCR is not tracking VHS tapes properly, I would find a way to connect directly to a composite monitor to troublshoot further.Last edited by dellsam34; 25th Feb 2025 at 13:00.
Does the Panasonic Omnivision SVHS VCR (PV-VS4821) have a service menu?
By supervehicle in forum Capturing and VCRReplies: 3Last Post: 16th Apr 2025, 20:45 -
REPAIR: Toshiba SV-771 SVHS VCR: Picture Search: Tension Lost Momentarily
By MrCreosote in forum RestorationReplies: 2Last Post: 28th Oct 2023, 23:17 -
Outputting Frame Sequence Images to Create A Single Image
By imaginethat in forum EditingReplies: 31Last Post: 19th Jan 2022, 08:25 -
Philips N1700 VCR & VC cassettes, European NASA broadcasts
By Dutchsteammachine in forum Capturing and VCRReplies: 30Last Post: 24th Apr 2021, 09:06 -
Capturing SVHS using a standard VHS VCR - Is it possible?
By DJ Kris in forum Capturing and VCRReplies: 15Last Post: 4th Jul 2020, 12:00
