HI, I would like to download these episodes, can you help me?
https://la.axn.com/series/master-crimes/videos
I have no idea how to work this streaming sites and tools. Thank you.
Use this tool and get the download command
https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping
For example for this video
https://la.axn.com/series/hawaii-five-0/videos/spencer-oculta-algo
you can download using
You need an IP from a latin american country. For example ColombiaCode:N_m3u8DL-RE "https://na2.stream.cdn.zype.com/vod/608fe6e1eb1000000130821e/663521fa73a39f0001372949/663521fa73a39f000137294a/1737912900/stream.mpd" --key 33f2e4e0f9b4d34f00c7cf6f101abf56:f330d82adcc6cf55d675eed1407cdca4 -M format=mkv
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Worked like a charm! Thank you so much!
Also, what is the difference if i use the Shaka Packager in that tool?
And finally, is it possible to use the same tool for Prime video?
Thanks! -
As tools of decryption you have mp4decrypt and shaka packager. If you remove the parameter --use-shaka-packager, then mp4decrypt is used by default. The only thing worth mentioning is that some videos (rare) may not decrypt correctly (sync included) with mp4decrypt, but work with shaka, and vice versa.
Headers Video AXN Spain
By axnspain in forum Video Streaming DownloadingReplies: 14Last Post: 10th Sep 2024, 15:06 -
Download from AXN Spain
By axnspain in forum Video Streaming DownloadingReplies: 18Last Post: 29th Mar 2024, 20:04 -
Get_iPlayer won't download BBC Sounds when setting the download directory
By VideoFanatic in forum Video Streaming DownloadingReplies: 5Last Post: 24th Jan 2024, 19:40 -
A GUI to download bulk download files through their respective M3U8 links
By UNforces885 in forum Video Streaming DownloadingReplies: 4Last Post: 4th May 2023, 14:04 -
How do I download AXN promos?
By axnspain in forum Video Streaming DownloadingReplies: 0Last Post: 23rd Oct 2020, 14:27
