I successfully obtained the keys to a live video stream and am decrypting it using N_m3u8DL-RE. However, when I attempt to play it using either MPV or VLC, I see a garbled video output, as shown in the screenshot. Does anyone have any ideas? Thanks.
Possible issues
- wrong keys
- the quality doesn't match your keys, try going for a lower res
- ads are breaking the manifest
- mp4decrypt issue, go for shaka packager
Can you provide the full unedited n_m3u8dl-re command or the original video url?Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 22nd Feb 2025 at 11:44.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Thanks for the quick reply. I suspect it could therefore be the wrong key.
I tried shaka-packager and that also made no difference. Here is my n_m3u8dl-re command:
I've removed the identifiers so that I'm within the forum rules.Code:/home/user/N_m3u8DL-RE --key <key>:<key>--save-name _TEST "https://url.mpd" --live-real-time-merge --tmp-dir TMP --live-pipe-mux --select-video for=best --select-audio lang=en:for=best --decryption-engine SHAKA_PACKAGER --decryption-binary-path /home/user/shaka-packager
So you basically want something decrypted by not revealing the n_m3u8dl-re command or the url. Ok. Can't do much besides recommending
https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping
More than that, you might as well ask in private other users--[----->+<]>.++++++++++++.---.--------.
Thanks for the advice. I think the key got updated without me realising - I obtained the encryption key again and it seems to work fine. Interestingly, a benefit of using Shaka Packager is that it immediately becomes obvious if the key is wrong whereas it is not so clear with mp4decrypt.
MKVToolNix garbled segment transitions on playback...
By takeajustin in forum Video ConversionReplies: 2Last Post: 15th Oct 2024, 14:45 -
AVerMedia CE310B issues (garbled output, macrovision)
By ConsumerDV in forum Capturing and VCRReplies: 19Last Post: 26th Feb 2024, 05:18 -
All of a customer's MiniDV tapes are garbled - any help?
By cinemaghost in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 6th Dec 2023, 15:21 -
AAC-LC sound garbled
By Loup in forum AudioReplies: 6Last Post: 31st May 2022, 08:51 -
AVFS serves garbled/slanted video even when AVS script plays fine
By Jellybit in forum Video ConversionReplies: 2Last Post: 2nd Aug 2020, 10:37
