Hello. Looking to buy a Blu Ray Drive. Did some research and liked this one. I am new trying to learn how to rip and burn dvd's, blu ray and music cd's.
There were pretty good reviews' on this one but a few people were not happy with it.
I would like feedback please on this device. Does it have everything I need? Is it missing anything I need? It comes with software I don't particularly want to use. Any advice on this device really appreciated. Any recommendation's on another devices appreciated also. Thanks
Pioneer External Blu-ray Drive BDR-XS07UHD @6X Slot Loading Portable with a Matte-Black Body USB 3.2 Gen1(3.0) BD/DVD/CD Writer. Firmware 2023 (Version: 1.03 and up). Cyberlink Software Included
Operating System Windows 11, Windows 10, Windows 8.1, maxOS Sequoia 15, macOS Sonoma 14, macOS Ventura 13, macOS Monterey 12, macOS Big Sur 11, macOS Catalina 10.15, macOS Mojave 10.14, macOS High Sierra 10.13, macOS Sierra 10.12, Mac OS X El Capitan10.11Windows 11, Windows 10, Windows 8.1, maxOS Sequoia 15, macOS Sonoma 14, macOS Ventura 13, ma… See more
Special Feature Portable, Vertical Mountable, CD Burner
Hardware Interface USB Type C, USB 3.2 Gen 1
Brand Pioneer
Optical Storage Write Speed 6x
About this item
Firmware 2023 (version: 1.03 and up)
Long-term data protection with M-DISC Support Support reading and writing M-DISC(DVD, BD: SL25GB/DL50GB/TL100GB) introduced by Millenniata, Inc.
Equipped with USB Type-C connector From XS07 series, the drive has USB Type-C connector. USB Type-C Cable (USB Standard A to USB Type-C and USB Type-C to USB Type-C ) included.
Compact, well-balanced body Feel smooth with rubber coating. Compact, well-balanced body with vertical stand.
Slot loading mechanism Both dependable dustproof and excellent quietness have been realized with original slot loading mechanism.
one bad review
The Cyberlink PowerDVD software license provided with this drive is "CyberLink Media Suite 14 OEM". Current version is version 22. When trying to play a standard Blu-ray disk, the software pukes, will not play, makes you download a Ultra HD Blu-ray Advisor that proceeds to tell you that in order to play a standard Blu-ray disk you need "PowerDVD 15 Ultra (Retail version) version or above. Thank you Pioneer for providing software that does not play Blu-ray disks of any kind.
The Cyberlink PowerDVD software will not play Ultra HD Blu-ray disks for several reasons, the first of which is that INTEL DOES NOT SUPPORT PLAYBACK OF ULTRA BLU-RAY COPY PROTECTED MATERIAL SINCE 2021 when they dropped support of their SGX trusted execution enviornment from their processors that are in all laptops and desktops. Does Pioneer not know this?!? Of course they do. Furthermore, again the Cyberlink Ultra HD Blu-ray Advisor software states that (among other reasons) that Cyberlink "PowerDVD 17 Ultra (Retail version) or above" is required to play Ultra HD Blu-ray disks.
Results 1 to 1 of 1
ISO External Blu-Ray (or 4k blu-ray) burner drive for PC (Windows 11)
By derricomonico in forum Blu-ray RippingReplies: 3Last Post: 16th Sep 2024, 16:16 -
External Blu Ray Drive for a New PC Case without a 5.25" Bay
By Subtitles in forum DVD & Blu-ray WritersReplies: 31Last Post: 7th Jan 2024, 04:04 -
External Blu Ray Drive reads DVDs very slow but advertised as 8X Read.
By VideoDRONE in forum DVD RippingReplies: 6Last Post: 29th Jul 2023, 14:42 -
Best external Blu-ray burner drive for Mac?
By Kal-El in forum MacReplies: 5Last Post: 17th Jul 2020, 07:50 -
Recommended external Blu-ray drive?
By Jeikobu in forum MacReplies: 7Last Post: 11th Mar 2020, 20:02
