Hello!
I have been using Media Player Classic (aka MPC-HC) since Windows XP without issues. Back then the only audio output options were either Default WaveOut Device and Default DirectSound Device, so I use the Default DirectSound Device ever since. Recently I noticed a weird bug, after I had played some videos, suddenly the next video was silent. I checked and confirmed my audio card is working properly everywhere else. The same video plays with sound at MPC-BE (Black Edition) or VLC. It was also playing OK in MPC-HC before this bug appeared, so it is not due to missing codecs. It is not due to configuration or other setting, as I did nothing relevant. Once the last video finished, I opened another, I didn't touch any settings.
Temporary fix: If I select the Default WaveOut Device, nothing changes, the video plays without sound. If I select the SaneAR Audio Renderer, the sound plays perfectly. Once I return to Default DirectSound Device the sound plays again for the first video but mutes for the next video! Weird! SaneAR Audio Renderer always have sound since probably it accesses the audio card independently from the standard Windows methods. But I would prefer to use the Default DirectSound Device as before. Anyone else encountered the same bug? Is there a fix? I haven't checked for any new MPC-HC version, could this bug be fixed in a newer version? I'm currently using version 2.3.9.28 from 29th January 2025.
Results 1 to 1 of 1
How can I set default video orientation / rotation on MPC?
By kal in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jun 2024, 01:01 -
Recording on hauppauge from roku device no sound
By wxman in forum Video ConversionReplies: 7Last Post: 13th Aug 2023, 15:18 -
Suddently MPC-HC & MPC-BE no video but got sounds, help!
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 5th Mar 2022, 04:57 -
amplify sound in mpc-hc?
By rocketman122 in forum Newbie / General discussionsReplies: 3Last Post: 14th Sep 2021, 23:36 -
sync offset and jitter values in mpc-hc and mpc-be
By Milardo in forum Capturing and VCRReplies: 0Last Post: 16th Nov 2020, 18:29
