I'm showing my lack of knowledge here so this might be a daft one.
I'm processing a lot of old tapes, capturing to Huffyuv AVI, deinterlacing to ProRes, then importing to Resolve. Some of the files end up on YT or social media so I'm using MOV(H265) files for my output.
I sometimes include watermarks/logos on the clips, but if I were to rebrand, it seems a huge pain to have to go through all the source files again, deinterlace again, and re-render from Resolve.
I'm thinking that it might be better idea to render out a version for YT with no watermarks/titles/logos initially, and if I need to add anything later I can simply import that H265 MOV file to Resolve, add the 'current version' of my branding/logos and output the file.
Will I lose quality if I import the MOV file, add a logo/watermark and re-render in Resolve, or are only the modified pixels changed?
Edit: Part of the motivation here is to remove the requirement to keep my source Huffyuv AVIs long term due to massive file sizes.
	Thanks. Is there anything specific to H265 that would result in lower loss than say a different codec? Typically for my YT uploads I output from Resolve at the highest quality (something like 25000kbps bitrate) which is probably overkill but I'm thinking if the bit rate is already higher than YT expects, would a re-render really impact that much.
	No, it is not possible, unless you use the original video capture material and include the logo from the beginning. Rendering two copies, one with the logo, one without is your best option (in my opinion) but for youtube, don't they re-encode uploads anyway? Your original capture material is the best source you have to work from should you ever want to alter or amend things in the future. They are the last things to dispense with, surely?
 TeraBox give you a terabyte of free storage. Upload the youtube versions you create there and you haven't any storage problems.
 Shutter Encoder claims to do some non-destructive things, but I have my doubts.
  Testing H264/AVC frame accurate editing (AVCHD/MOV/MP4/MKV)) of SolveigMMBy DmitryV in forum EditingReplies: 17Last Post: 20th Oct 2023, 06:47
  Error when trying to playback h264 .mp4 video. Help.By lovethisnation in forum Video ConversionReplies: 7Last Post: 23rd Jun 2023, 18:54
  Dvd to mp4 or mkv, h264 or h265 etcBy victoriabears in forum DVD RippingReplies: 8Last Post: 21st May 2022, 18:35
  Powerdirector better than Vegas rendering H264 AVCBy zizouillette in forum EditingReplies: 10Last Post: 1st Nov 2020, 19:20
  Handbrake Conversion DVD to MP4/H264By microkid2020 in forum DVD RippingReplies: 10Last Post: 4th Jul 2020, 12:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
