Hope someone can help me ,
im trying to open a M3U8 file i was able to download from Veeps but when file doesn't seem to open. its about 18gb file. Im using MacOS
thanks
Closed Thread
Results 1 to 18 of 18
How did you download it? Have you decrypted it?
I downloaded with Live Stream Downloader its an mpd file but downloads as an mkv
I have no clue how to decrypt files
Is the livestream still on? Maybe you can still get its decryption key. If it's still on, post the URL. Or at least post the mpd URL/ m3u8 URL.
Ok, so according to the mpd's pssh
Code:AAAAP3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAB8SEITQbrB0sEH7kGEqQ7JcdYUaBWV6ZHJtSOPclZsG
Code:84d06eb074b041fb90612a43b25c7585:06fc5a2d6c900d20e080ce564739c26c
You told the program finished downloading. I want to see what it downloaded. Is it just 1 mkv file? mp4? Multiple files: part1, part2, etc. ?
I am not 100% sure if those are the right steps. But since it's mkv and both tracks are encrypted, try extracting them in separate files: video.avc and audio.aac for example (the extensions might be different). You can use gMKVExtractGUI
Copy both files in an empty folder, and also download and put there mp4decrypt (look for mp4decrypt executable in the archive file)
https://www.bento4.com/downloads/
Then open cmd in that folder and run
Code:mp4decrypt --key 84d06eb074b041fb90612a43b25c7585:06fc5a2d6c900d20e080ce564739c26c video.avc video_decrypted.avc mp4decrypt --key 84d06eb074b041fb90612a43b25c7585:06fc5a2d6c900d20e080ce564739c26c audio.aac audio_decrypted.aac
If it fails you could upload that 18gb file somewhere for others to try.--[----->+<]>.++++++++++++.---.--------.
Well the mpd you posted isn't a livestream anymore so you can download the 3 hour vod using
Code:N_m3u8DL-RE "https://d1gf363n2c1czk.cloudfront.net/ba476eb2-e7f8-45f9-ad09-0a0522e0d4cc/HLS/5642c90d-8259-4797-81e7-0b656208b336/5b70c774-3e71-4849-99d4-6eaea2aefd82/widevine_cmaf_avc.mpd" --key 84d06eb074b041fb90612a43b25c7585:06fc5a2d6c900d20e080ce564739c26c -M format=mkv
Command is good. It downloads a 18.5 gb file at 4k res. Make sure you installed n_m3u8dl-re properly together with ffmpeg and mp4decrypt in the same folder. Show a screenshot with the folder structure and also the command with its console logs
Downloading video from Veeps?
By tacobellcry in forum Video Streaming DownloadingReplies: 3Last Post: 12th Oct 2024, 14:53 -
Help with Veeps!
By stefanthehuman in forum Video Streaming DownloadingReplies: 11Last Post: 11th Sep 2024, 07:17 -
Help with Veeps!
By hypnicjerk in forum Video Streaming DownloadingReplies: 9Last Post: 26th Jul 2024, 03:45 -
Help with Veeps
By gvtters in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jul 2024, 05:17 -
Streaming decrypted live stream - live pipe buffering problem
By Kalisto in forum Video Streaming DownloadingReplies: 0Last Post: 25th Apr 2024, 12:19
