Its been all long battle spanning several weeks using a variety of different software. But alas I've met my Waterloo.
You know I come and look at this forum and I see lots of people making good quality VCDs. When I make a VCD it plays brilliantly on my PC but when I try playing it on my VCD player the video stutters every few seconds. I've downloaded VCDs and they play fine in my player.
I don't know how you guys are making it happen I alas have been unable to. Yes I tried all the software, all the tutorials tried all the tweeks.
Its finally come to this. I am giving up trying to make them. So, where in the UK can I buy good quality VCDs?
Kind regards
And thanks to those how have tried helping.
CakeHole
Before you give up making VCD, could you tell me what your parameter setting was in TMPGEnc?
The Dutchman -
I used the VideoCD PAL template which was supplied with TMPGEnc. And set the aspect ratio to 16:9 (PAL). And took out the Detect Scene Changes in GOP structure.
Tried both Interlaced and Progressive (with both Field A and Field B). And video arrange method I left at Full Screen (keep aspect ratio).
Regards
Alan
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
What is smpeg4 and is there a better way to convert then vcd?
By yoda313 in forum Video ConversionReplies: 12Last Post: 13th Mar 2009, 18:26 -
how to convert dvdrip avi's to vcd
By kissme1 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 9th Dec 2008, 15:19 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:51 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
