Hi,
Until a few weeks ago I was able to download and decrypt TeleQuebec.tv video without any issues using WidevineProxy2, N_m3u8DL-RE and my Widevine device I generated with an Android emulator.
However now it decrypt the ads and then it's just a gray image with artifacts and the sound is non sense (seems it fails to decrypt the actual content)
Here's an example
https://video.telequebec.tv/details/52869
Any idea?
Thank you
https://www.swisstransfer.com/d/c7022031-bad8-4346-b6e7-d78424de9d5bCode:
a9216f0e2c9d4263b4c52acc205cff5d:8c072afef9ffc811440d3fb0693a6e93
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Use
https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping
Copy the download command. I didn't use the parameter --use-shaka-packager and left it with -M format=mkv
Seems to do the job. Also don't select the subtitles because they're broken. If you mux with broken subtitles that are longer than the video, you'll get for the extra subtitle time a black screen. Download separately the subs, and fix them with subtitleedit if you need them.--[----->+<]>.++++++++++++.---.--------.
Well that's something, as you suggested I've disabled the subtitles and now it decrypt the video and audio as expected. In my case with the subtitles the entirety video would be a gray images with some artifacts and the audio scramble.
Anyway,
Thank you a lot
Need help to download TeleQuebec.tv video
By Bbz in forum Video Streaming DownloadingReplies: 7Last Post: 24th Dec 2024, 07:32 -
Help to decrypt video please ?
By yefije1370 in forum Video Streaming DownloadingReplies: 12Last Post: 4th Nov 2024, 12:50 -
decrypt video from app
By killua in forum Video Streaming DownloadingReplies: 15Last Post: 1st Oct 2024, 13:11 -
Unable to decrypt the video.
By asiffff77@proton.me in forum Newbie / General discussionsReplies: 1Last Post: 23rd May 2024, 12:25 -
I have video and key but i can't decrypt
By noctus in forum Video Streaming DownloadingReplies: 3Last Post: 30th Jan 2021, 03:42
