Hi, I'm wondering if anyone knows how I can crop a video I have screen recorded in OBS video to 4:3?. I captured the recording at 1920x1080 (capturing the whole screen area), but I am wanting to crop off the black borders to the left and right and make the video 4x3. I've tried Handbrake by cropping the sides but it doesn't seem to crop the video. thanks.
				Results 1 to 14 of 14
	You have to crop 240 pixels from the right and 240 pixels from the left and re-enode as 1440x1080 (=4:3)
	I find Handbrake's cropping screen isn't intuitive. To achieve what you want, set it up like this:
 [Attachment 85570 - Click to enlarge]
	Thanks for that. Yeah I did try and change the size, but it kept changing the 1080 to a different number, no idea why. Can changing the aspect be done in any other program besides Handbrake, one that will allow me to trim the video?. I know Handbrake has an trim/edit feature but it's not very good IMO.
 Edit: Just noticed it's because I didn't click "none" for resolution limit.Last edited by techmot; 18th Feb 2025 at 07:26.
	Basically you're after a video editor. The venerable VDub2 is free and pretty simple to use. My Start to Finish guide here.
 There are probably other, more-modern freeby out there. Have a look at the video editors in the software section on VH.
	Absolutely, and better still, it shows you the actual cropped size; you visually drag in the sides to crop off what you want. You can more easily keep track of maintaining the 4:3 ratio.But VDub can't crop a video, or can it?
 PS: Use VDub2. In VDub1, there's no specific "crop" filter; you have to invoke another filter first, then the "cropping" button comes alive. Silly system which was ditched in VDub2.
	My YouTube channel with little clips: vhs-decode, comparing TBC, etc.
	Shutter Encoder, maybe to your liking:
 Quickly crop your images
 By using the "Image" function you will have the possibility to quickly and easily crop your images as well as your videos. You can define your frame precisely by writing directly your values in pixels.
	I tried Avidemux and it does enable you to crop the borders. I think using Avidemux is better than with Handbrake if you intend to also trim/edit videos easily and encode. I suppose using a dedicated editing program like Adobe Premiere or something free to use like VSDC is better if you intend to add text and effects as well as trim the files. Last edited by techmot; 20th Feb 2025 at 14:32.
	Also, does anyone know how to do the same cropping in Premiere Pro?. When I changed the size from 1920x1080 to 1440x1080, it took the left and right black borders off, but also cropped some of the image as well for some reason.
  Enlarge then cropping capture videoBy Jokris in forum Newbie / General discussionsReplies: 25Last Post: 30th Oct 2024, 06:19
  Benefits of video cropping?By maverickluke in forum Video ConversionReplies: 42Last Post: 3rd Oct 2021, 13:58
  Can video playing on-screen be captured using a graphics card?By gddpb in forum Capturing and VCRReplies: 2Last Post: 8th Nov 2020, 07:06
  Cropping/Blurring a logo on videoBy new93 in forum EditingReplies: 7Last Post: 19th Aug 2020, 07:52
  Variable audio drift from screen captured VR project in UnityBy slopate in forum Newbie / General discussionsReplies: 15Last Post: 10th Jun 2020, 22:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
