DVDShrink can merge ISOs or folders. Just add them using the Open Disc Image or Open option. Years ago when I used to backup to discs, I split my DVD-9 into two DVD-5, then later merged them back into a DVD-9 for recovery. The second disc has a short "Insert disc 1" message that you have to remove manually. IIRC, it appears as a separate IFO and VIDEO_TS.
As with PCGEdit, the menu will work only if the two parts are from the original DVD-9
Results 31 to 42 of 42
download it from the software section of this site
https://www.videohelp.com/software/ImgBurn -
The link davenet posted for videohelp will work fine.
I have never had a problem with a download from videohelp.
If you do want to download ImgBurn from the ImgBurn website choose one to the mirrors including the #7 which is the web site.
https://www.imgburn.com/index.php?act=download
I can not say whether the DVDShrink would have merged this DVD back togather with all menu buttons working as they did with the DVD9 Full Movie rip.I doubt that it would .
I know that the DVDFab Merge function did not do this.
I will give it a try sometime in the next few days with DVDShrink after I do the split with DVDFab. -
As it was already mentioned, ripping should not have any effect on the quality of the playback since the 'rip' should be identical to what's on the DVD.
Personally, I use DVD Decrypter first, then AnyDVD if Decrypter fails (I have an old license for AnyDVD), and I *always* rip to an .iso file with them.
If both fails then I try MakeMKV next, but failure at that point is often a sign of some issue with the DVD, so MakeMKV may or may not help at that point. However, certain players have much better error correction than others, and can read DVDs that fail on most players.
DVD Decrypter is a 'forced abandonware' and so it is totally free, but even before that, it was only a 'donationware'. -
DVDShrink can be set for DVD9 so there is no compression.
It can also be "picky" so good to spot a problem DVD.
I also have the old AnyDVD HD & it still works well with DVDShrink.
I like & use DVDShrink's Analyze features.
Some do not like the logarithms DVDShrink uses for this but I find they improve most rips.
To me eyes.
Any good FREE software for Webcam please?
By mikehende in forum Newbie / General discussionsReplies: 4Last Post: 15th Nov 2024, 07:46 -
Free redact software
By jyeh74 in forum Off topicReplies: 3Last Post: 28th Jun 2021, 16:59 -
Help to ripping from this free TV
By Fathom in forum Video Streaming DownloadingReplies: 11Last Post: 27th Oct 2020, 09:20 -
Any software to make autorun DVD Ripping ?
By sherryparket in forum DVD RippingReplies: 4Last Post: 30th Jun 2020, 08:04 -
100% free software
By latecurtis in forum EditingReplies: 9Last Post: 21st Apr 2020, 11:29
