I use this program MPEG Streamclip 1.2.1b6 to join my videos that are in VOB format from DVDs. It's excellent, it doesn't cause any loss of the original file and it does the conversion job quickly. But I wanted to know if there is one that does the same job, is also fast, that doesn't make the files huge and that I can add audio from another file, just like VirtualDub does.
[Attachment 85538 - Click to enlarge]
Results 1 to 9 of 9
For unprotected DVD's you could try clever FFmpeg-GUI.
It rips the movie to a single mpg, for further elaborations.
Drag the first vob of the titleset (g.e. VTS_01_1.VOB) on the startscreen and answer yes and the whole titleset (1 from the example) will be ripped.
Then you can g.e. recode the videostream and/or the audiostream aso. -
Hi ProWo. I've got a request for you: can you add feature "Split" ? I noticed there are features Cut and Join, but Split is missing. Feature Split means:
2 (or more) equal size parts (just one process);
or split by selection (Start Time/End Time). For example: 1 hour lenght video can be splitted in 2 parts : first part 20 minutes lenght, second part 40 minutes lenght (ust one process).
Could you add this feature ? -
I don't understand. For example: how can I get 4 equal size parts in just one process ? What I have to do?
Another example: if I've got 1 hour video lenght and I cut by selection (start time 00:00:00 end time 00:20:00) I just get this parrt - 20 minutes lenght; I don't get the second part - 40 minutes lenght. I don't think function Split is added. Can you explain? -
As an example, for a movie with 01:00:00 duration, splitting in 4 equal parts:
Enter 00:00:00 as start and 00:15:00 as end, click check times, the 1st cut mark is setted.
Enter 00:15:00 as start and 00:30:00 as end, click check times, the 2nd cut mark is setted.
Enter 00:30:00 as start and 00:45:00 as end, click check times, the 3th cut mark is setted.
Enter 00:45:00 as start and 01:00:00 as end, click check times, the 4th cut mark is setted.
Then click cut, you get 4 equal parts.
The cuts ar made on keyframes, small time deviations are therefore possible.
MPEG Streamclip won't open mp4, solutions or alt programs?
By SkyWolfAlpha in forum MacReplies: 18Last Post: 13th Oct 2023, 02:46 -
What is the cause for external subtitles to grow further apart from audio?
By semmel in forum SubtitleReplies: 7Last Post: 27th Sep 2023, 08:00 -
Simple Audio Conversion Popcorn Audio Converter 1.88 doesn't work for E-AC3
By gergo7633 in forum AudioReplies: 2Last Post: 1st Jun 2021, 08:09 -
No Audio Recorded Using External Mic With Canon Vixia XA-11
By D.V. Dee in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 24th Dec 2020, 13:17 -
Dubbing external audio
By pooksahib in forum Video ConversionReplies: 2Last Post: 21st Oct 2020, 23:43
