  1. can I ask how I can play this continuously with tokenize link?
    https://www.sbs.co.kr/live
    Channels needed: all channels offered in the site.
  2. I've searched around here and nothing works, I don't have any knowledge on coding and getting some important info in dev tools so please help me. Tyia!
  3. What if you set up an API to fetch the latest manifest? Alternatively, you can use o11 for restreaming, which automatically refreshes the manifest. github.com/Random-Code-Guy/o11v4-Cracked ( works better for DRM protected streams, it’s not needed here) look at @2nHxWW6GkN1l916N3ayz8HQoi comment below.
    discord=notaghost9997
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Here's a small script that generates a streamlink working command for all live channels regardless of type: radio, tv, virtual. As @notghost said, you can adapt it for your own API. Some channels don't even work. I guess you need a paid account for them
    import json
    import requests
    from bs4 import BeautifulSoup
    BASE_URL = "https://www.sbs.co.kr/en/live"
    CHANNELS_URL = {
        "tv": "https://apis.sbs.co.kr/play-api/1.0/onair/channel/{channel_id}",
        "radio": "https://apis.sbs.co.kr/play-api/1.0/onair/channel/{channel_id}",
        "virtual": "https://apis.sbs.co.kr/play-api/1.0/onair/virtual/channel/{channel_id}"
    LIVE_URL = "https://www.sbs.co.kr/en/live/{live_id}"
    def get_streamlink_command(source_type, source_url):
        live_id = source_url.split("?")[0].split("/")[-1]
        try:
            sources = requests.get(
                CHANNELS_URL[source_type].format(channel_id=live_id),
                params={'protocol': 'hls'}
            ).json()["onair"]["source"]["mediasourcelist"]
        except:
            sources = []
        media_sources = []
        for source in sources:
            try:
                quality = int(source["quality"].replace("p", ""))
                media_url = source["mediaurl"]
                assert len(media_url) > 0
                media_sources.append((quality, media_url))
            except:
                pass
        try:
            media_source = sorted(media_sources, key=lambda m: m[0])[0][1]
        except:
            media_source = None
        return f"url: {source_url}\n" + f'command: streamlink "{media_source}" best\n'
    def get_channels(source_url):
        response = requests.get(source_url).text
        soup = BeautifulSoup(response, 'html5lib')
        response = soup.find('script', {'id': '__NEXT_DATA__', 'type': 'application/json'})
        response = json.loads(response.string.strip())
        channels = []
        visited = []
        for k, v in response["props"]["pageProps"].items():
            if type(v) is not list:
                continue
            for c in v:
                try:
                    if c["channelid"] in visited:
                        continue
                    visited.append(c["channelid"])
                    channel_url = LIVE_URL.format(live_id=c["channelid"])
                    channels.append((k, channel_url))
                except:
                    pass
        return channels
    if __name__ == '__main__':
        for ch_type, ch_url in get_channels(BASE_URL):
            print(get_streamlink_command(ch_type, ch_url))
    Output:
    url: https://www.sbs.co.kr/en/live/S01
    command: streamlink "None" best
    url: https://www.sbs.co.kr/en/live/S03
    url: https://www.sbs.co.kr/en/live/S04
    url: https://www.sbs.co.kr/en/live/S02
    url: https://www.sbs.co.kr/en/live/S05
    url: https://www.sbs.co.kr/en/live/S12
    url: https://www.sbs.co.kr/en/live/S06
    url: https://www.sbs.co.kr/en/live/S09
    url: https://www.sbs.co.kr/en/live/S11
    url: https://www.sbs.co.kr/en/live/S20
    command: streamlink "http://tvlive.sbs.co.kr/sbskpop/sbskpop2.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S07
    url: https://www.sbs.co.kr/en/live/S08
    url: https://www.sbs.co.kr/en/live/S19
    url: https://www.sbs.co.kr/en/live/SA4
    command: streamlink "http://sbs24tv.sbs.co.kr/file16/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S29
    command: streamlink "http://sbs24tv.sbs.co.kr/file9/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SB1
    command: streamlink "http://sbs24tv.sbs.co.kr/file29/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S30
    command: streamlink "http://sbs24tv.sbs.co.kr/file10/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SAD
    command: streamlink "http://sbs24tv.sbs.co.kr/file25/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SA5
    command: streamlink "http://sbs24tv.sbs.co.kr/file17/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SA7
    command: streamlink "http://sbs24tv.sbs.co.kr/file19/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S27
    command: streamlink "http://sbs24tv.sbs.co.kr/file7/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S26
    command: streamlink "http://sbs24tv.sbs.co.kr/file6/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S22
    command: streamlink "http://sbs24tv.sbs.co.kr/file2/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SA2
    command: streamlink "http://sbs24tv.sbs.co.kr/file14/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SA3
    command: streamlink "http://sbs24tv.sbs.co.kr/file15/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S28
    command: streamlink "http://sbs24tv.sbs.co.kr/file8/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S23
    command: streamlink "http://sbs24tv.sbs.co.kr/file3/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SA1
    command: streamlink "http://sbs24tv.sbs.co.kr/file13/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S32
    command: streamlink "http://sbs24tv.sbs.co.kr/file12/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S31
    command: streamlink "http://sbs24tv.sbs.co.kr/file11/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SAC
    command: streamlink "http://sbs24tv.sbs.co.kr/file24/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SAE
    command: streamlink "http://sbs24tv.sbs.co.kr/file26/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SAF
    command: streamlink "http://sbs24tv.sbs.co.kr/file27/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SAA
    command: streamlink "http://sbs24tv.sbs.co.kr/file22/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SA8
    command: streamlink "http://sbs24tv.sbs.co.kr/file20/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SAB
    command: streamlink "http://sbs24tv.sbs.co.kr/file23/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SA9
    command: streamlink "http://sbs24tv.sbs.co.kr/file21/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SB0
    command: streamlink "http://sbs24tv.sbs.co.kr/file28/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SB2
    command: streamlink "http://sbs24tv.sbs.co.kr/file30/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/SA6
    command: streamlink "http://sbs24tv.sbs.co.kr/file18/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S21
    command: streamlink "http://sbs24tv.sbs.co.kr/file1/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S25
    command: streamlink "http://sbs24tv.sbs.co.kr/file5/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
    url: https://www.sbs.co.kr/en/live/S24
    command: streamlink "http://sbs24tv.sbs.co.kr/file4/mediaurlC.stream/playlist.m3u8?token=<STREAM_TOKEN>" best
  5. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    import json
    import requests
    CHANNELS_URL = {
        try:
        except:
            sources = []
        media_sources = []
            try:
            except:
                pass
        try:
        except:
            media_source = None
        channels = []
        visited = []
                continue
            for c in v:
                try:
                        continue
                except:
                    pass
        return channels
    Output:
    I'll try this one, thank you for this!
