I'm requesting https://www.bbc.co.uk/iplayer/episode/m0011p5h/abba-in-switzerland in its best quality without the DRM. I'll use N_m3u8DL-RE for this. Thanks in advance.
Results 1 to 26 of 26
We all bleed blue from the inside....
https://www.swisstransfer.com/d/9ce37193-489c-486f-a260-449e15cb0eb5 1080p is best res I can get for this
Same logged twice here's your file -
Thanks so much!
We all bleed blue from the inside.... -
This is a 3 hour broadcast, but when I download with Videomass (Mac), I am only getting a 40-minute file. I have downloaded other files and get the full 3 hours. I'm wondering if anyone can help me either with a file or to compare your process and see if you run into the same problem. Thanks in advance for the help.
FYI, I think the file will disappear on Tuesday since the 5 Live Sports broadcasts tend to last for 7 days.
https://www.bbc.co.uk/sounds/play/m002hnqh -
Thanks so much for helping me with this one. I really appreciate it.
I'm wondering if I can get help with another audio file. I'm having the same problem in that Videomass outputs a 35 minute file and JDownloader reads the link as a website file. The file should be 3 hours 15 minutes.
https://www.bbc.co.uk/sounds/play/m002m4jw -
LupineAssassin or any other helpful friend, is it possible to get this one? I get an error with Videomass. It is available for 5 more days.
https://www.bbc.co.uk/sounds/play/m002lc8z -
https://buzzheavier.com/byb79ah9l4e0Code:
N_m3u8DL-RE "https://aod-dash-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_audio/4de0bf-m002lc8y/vf_m002lc8y_c3f9d2c9-19a5-4fe3-8398-b3d3c0310708.ism/pc_hd_abr_v2_uk_dash_master.mpd?__gda__=1764212316_231af537bf79f3c95f27e81a21dbcb92" --save-name "Rotherham United v Swindon Town 01.11.2025"
Thanks, ListyDoM and vidsrme! How were you able to get this one?
If you setup/install N_m3u8DL-RE or yt-dlp you can use either of those in combination with Stream Detector Firefox or Chrome.
Another request for some help. As with one of my previous requests, Videomass keeps giving me a short file instead of the full broadcast. Thanks in advance if anyone can grab the full 185 minute file.
https://www.bbc.co.uk/sounds/play/m002q83f -
I managed to get this:
N_m3u8DL-RE "https://aod-dash-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_audio/be99a6-m002q83d/vf_m002q83d_b61f4a81-ba92-4559-af83-d156ec1b0ef7.ism/pc_hd_abr_v2_uk_dash_master.mpd?__gda__=1768568484 _6ff81c33261e2ea4a460091b10863b07#t=6" --save-name "pc_hd_abr_v2_uk_dash_master"
but I'm having trouble grabbing it with CMD.We all bleed blue from the inside.... -
Use stream detector
https://buzzheavier.com/rey0k8pkec3gCode:N_m3u8DL-RE "https://aod-dash-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_audio/be99a6-m002q83d/vf_m002q83d_b61f4a81-ba92-4559-af83-d156ec1b0ef7.ism/pc_hd_abr_v2_uk_dash_master.mpd?__gda__=1768576312_d2ebe444fc44331009cc74d44b6ac996" --header "User-Agent: Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0" --header "Referer: https://www.bbc.co.uk/" --save-name "FA Cup Football - 2025-26 - Newcastle United v AFC Bournemouth - BBC Sounds"
I'm having a problem again where Videomass outputs a file that is shorter than the streaming audio. Can anyone help me with an audio file for this match? Thanks.
https://www.bbc.co.uk/sounds/play/m002y3cw -
You didn't say which format required, so..
As original on-site m4a
https://www.swisstransfer.com/d/525351bd-7247-4b7e-8906-5e015e7a32f6
Mp4 format
https://www.swisstransfer.com/d/90c9f98b-9b16-4879-9bf4-261384baa228Last edited by YmFzZTY0; 23rd Jun 2026 at 06:32.
Thanks, ym. I appreciate it. Either format was good so thanks for the choices.
Getting BBC Iplayer mpds
By BerlinGen in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Jan 2025, 11:23 -
BBC iPlayer problem.
By bex147 in forum Newbie / General discussionsReplies: 15Last Post: 15th Mar 2024, 05:13 -
BBC iPlayer
By Ivan in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Feb 2024, 08:02 -
BBC iPlayer help needed
By Ebi in forum Video Streaming DownloadingReplies: 6Last Post: 19th Feb 2024, 17:33 -
BBC iplayer download dimensions
By David Banner in forum Video Streaming DownloadingReplies: 1Last Post: 17th Sep 2021, 15:26
