I read all the post i found useful related to my issue but i still cant solve this download issue HTTP Error 403: Forbidden
tried all tools: N_m3u8DL, yt-dlp, hlsdl, ffmpeg all 403 issue
tried with updated cookie.txt, somehow cloudflare still blocking the downloads causing the 403
the website is selfhosted & the player is embed protected on a website
To run the video
when the video loadsHTML Code:Example Video: https://imcvideo.com/e/hh5wa7viiujp?s1.imcvideo.com/i/03/00010/hh5wa7viiujp note: the embed video wont work directly you need to pass a referrer to run the video download header editor extension (firefox) then set the referer like this > https://i.postimg.cc/nhBr19D9/Screenshot-2025-02-13-194451.png now run the video it will redirect to https://imcvideo.com/dl & load the video debugger locked, so you need to manually start > unpause the debugger option then f8 button
when the video loads it also load some m3u8
HTML Code:https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/index-v1-a1.m3u8?t=ZVXI7_zkSaba69RScPE_erwhZjYZIawnarA6GIJp7Bc&s=1739446603&e=43200&v=121386&i=0.3&sp=1000 https://imcvideo.com/dl?op=getipvtt&length=298 https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/master.m3u8?t=ZVXI7_zkSaba69RScPE_erwhZjYZIawnarA6GIJp7Bc&s=1739446603&e=43200&v=121386&i=0.3&sp=1000 https://imcvideo.com/dl?op=getipvtt&length=298.35 https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/master.m3u8?t=LwSfGWAxwFgAova6LlSeVyCRzLUCfbHof6PRFOHZOQ4&s=1739446602&e=43200&v=121380&i=0.3&sp=1 https://imcvideo.com/srt/empty.srt
the index-v1-a1.m3u8 response:
master.m3u8 response:HTML Code:#EXTM3U #EXT-X-TARGETDURATION:10 #EXT-X-ALLOW-CACHE:YES #EXT-X-PLAYLIST-TYPE:VOD #EXT-X-KEY:METHOD=AES-128,URI="https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/encryption.key?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000" #EXT-X-VERSION:3 #EXT-X-MEDIA-SEQUENCE:1 #EXTINF:10.000, https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/seg-1-v1-a1.ts?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000 #EXTINF:10.000, https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/seg-2-v1-a1.ts?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000 #EXTINF:10.000, https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/seg-3-v1-a1.ts?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000 #EXTINF:10.000, https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/seg-4-v1-a1.ts?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000 #EXTINF:10.000, https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/seg-5-v1-a1.ts?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000 #EXTINF:10.000, https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/seg-6-v1-a1.ts?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000 #EXTINF:10.000, https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/seg-7-v1-a1.ts?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000 #EXTINF:10.000, https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/seg-8-v1-a1.ts?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000
HTML Code:#EXTM3U #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=224656,RESOLUTION=1312x720,FRAME-RATE=60.000,CODECS="avc1.640028,mp4a.40.2",VIDEO-RANGE=SDR https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/index-v1-a1.m3u8?t=HQvXqexxDkQT3dtB0G8yGPzCIbeW9YSVyl7eIxwxlNw&s=1739454426&e=43200&v=121634&i=0.3&sp=1000
i tried with updated cookie, changed user agent, added referrer still 403 error, note: the website blocks vpn ip so i tried local no luck
i wish someone please help me solve this
some of the command i tried(tried more wasted 3 hours:( ) :
all 403 forbidden issueHTML Code:yt-dlp --no-part --restrict-filenames -N 4 --user-agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:135.0) Gecko/20100101 Firefox/135.0" --cookies cookies.txt --add-header "Referer: https://imarketing.courses/" --add-header "Origin: https://imcvideo.com/" --hls-prefer-ffmpeg "https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/index-v1-a1.m3u8" yt-dlp --no-part --restrict-filenames -N 4 --user-agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:135.0) Gecko/20100101 Firefox/135.0" --add-header "Cookie:cf_clearance=removed" --referer "https://imcvideo.com/dl" "https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/index-v1-a1.m3u8" N_m3u8DL-RE "https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/index-v1-a1.m3u8" --header "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36" --header "Cookie: cf_clearance=removed" --header "ref_url: imarketing.courses" --save-name "master" ffmpeg -user_agent "User-Agent:Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36" -headers "Cookie: cf_clearance=removed" -referer "https://imarketing.courses/" -i "https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/master.m3u8?t=X1TFH8cvsTSZzRB1LupQyYCeEIorRa6ELNJEHxotDw0&s=1739445544&e=43200&v=121370&i=0.3&sp=1000" -c copy "master.ts"
This is a weird one. If it fails, make sure you're using your own user agent and language header values. Key URL is most likely a one time request since you can only download it once
Code:N_m3u8DL-RE "https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/index-v1-a1.m3u8?t=ZVXI7_zkSaba69RScPE_erwhZjYZIawnarA6GIJp7Bc&s=1739446603&e=43200&v=121386&i=0.3&sp=1000" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:135.0) Gecko/20100101 Firefox/135.0" -H "Accept-Language: en-US,en;q=0.5" --custom-hls-key 648485FAAC66E968CBDDF4F74DB62CFC -M format=mkv
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Thanks mate, do you know how to request 1080p stream of the file? the file hosted Res is 1080p high bitrate showing me 720p crap.
xvideosharing kind of site with cloudflare
it will require javascript evaluation to get pass cloudflare
Code:https://imcvideo.com/dl?op=embed&file_code=hh5wa7viiujp (with Referer header set as "https://imcvideo.com/") hh5wa7viiujp_x = UHD quality hh5wa7viiujp_h = HD quality hh5wa7viiujp_n = Normal quality hh5wa7viiujp_l = Low quality download page blocked by admin: https://imcvideo.com/d/hh5wa7viiujp
On their html page you have an eval js code block. When you run it in node js to get rid of the obfuscation, you get another expanded js code. There you have this
Code:{ sources: [{ file: "https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/master.m3u8?t=g-cu5emF-SPXywAxND63jBD-KGog6qdq2SlvcZxa4Eo&s=1739470213&e=43200&v=122177&i=0.3&sp=1" }], withCredentials: true, image: "https://s1.imcvideo.com/i/03/00010/hh5wa7viiujp.jpg", width: "100%", height: "100%", stretching: "uniform", duration: "298.35", fullscreenOrientationLock: "none", preload: 'metadata', androidhls: "true", tracks: [{ file: "/dl?op=getipvtt&length=298.35", label: "xxx", kind: "captions", "default": true }, { file: "/srt/empty.srt", label: "Upload captions", kind: "captions" }], captions: { userFontScale: 1, color: '#FFFFFF', backgroundColor: '#303030', fontFamily: "Tahoma", backgroundOpacity: 30, fontOpacity: '50', }, 'qualityLabels': { "224": "Normal" }, abouttext: "Imarketing Courses", aboutlink: "https://imarketing.courses", cast: {}, playbackRateControls: true, playbackRates: [1, 1.25, 1.5, 2] }
i checked all the links with quality _x _n _l _h
only _n is working others throwing 404 not found means disabled only 720 enable by default
another thing i found without those quality selector the link is throwing 403 error which means if my browser can fetch the original without quality selector, i can get the original file stream
Normal 720p link: "https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp_n/master.m3u8?t=g-cu5emF-SPXywAxND63jBD-KGog6qdq2SlvcZxa4Eo&s=1739470213&e=43200&v=122177& i=0.3&sp=1"
Orginal (maybe 1080p) link: "https://s1.imcvideo.com/hls2/03/00010/hh5wa7viiujp/master.m3u8?t=g-cu5emF-SPXywAxND63jBD-KGog6qdq2SlvcZxa4Eo&s=1739470213&e=43200&v=122177& i=0.3&sp=1" this link 403 error because cant match user agent, need to pass via a browser agent (where it runs & give cf_clearance cookie)
i guess
Error while downloading YouTube video with online downloader: 403 error
By DiggaDigga2010 in forum Video Streaming DownloadingReplies: 6Last Post: 22nd Dec 2024, 16:03 -
Downloading encrypted m3u8 with encrypted key
By alanonymous in forum Video Streaming DownloadingReplies: 4Last Post: 29th Mar 2022, 09:51 -
Need help downloading extm3u with aes128 encryption
By Prince7589 in forum Video Streaming DownloadingReplies: 3Last Post: 12th Dec 2021, 14:05 -
403 Forbidden Error while downloading from mpd link from Airtel Xstream
By ank03 in forum Video Streaming DownloadingReplies: 4Last Post: 4th Oct 2021, 08:56 -
yt-dlp error "HTTP Error 403: Forbidden". MPD downloading [ABC.com site]
By nikshell29 in forum Video Streaming DownloadingReplies: 5Last Post: 26th Aug 2021, 15:18
