I have a large library of encoded movies and shows but I am working on making some older encodings come closer to being on par with what I do now. These movies are already encoded in HEVC and although my new settings are superior there will be no gain in re-encoding them but I do want to inverse telecine them to bring them to 24fps. Is there a way with ffmpeg to do this without re-encoding? I ran some files through FFmpeg Batch AV Converter using my normal settings and they worked but were re-encoded so I would rather just inverse telecine them, is this possible?
Thanks.
Can you post a short clip of your source, something with some steady movement?
Does your source have duplicates frames?
I don't think it's possible without a re-encode -
[AnimeIVTC] Inability to Inverse Telecine
By DEFiANT in forum RestorationReplies: 7Last Post: 17th Jan 2025, 07:19 -
How to inverse telecine NTSC 29.97 -> 23.976 in Avisynth
By VideoMilk78 in forum RestorationReplies: 4Last Post: 9th Nov 2024, 12:52 -
Inverse Telecine: Double Checking My Work
By pulsar8 in forum RestorationReplies: 15Last Post: 30th Jun 2023, 13:52 -
480i Inverse Telecine - Audio Falling in/out of Sync
By ThaKarra in forum Video ConversionReplies: 4Last Post: 3rd Jun 2021, 19:10 -
DVD Inverse Telecine ?
By dolpsdw in forum Newbie / General discussionsReplies: 9Last Post: 16th Dec 2020, 08:15
